TERM: Undefined variable.
swiss196
I've recently set up a new FreeNAS server for personal use.
Having configured it, I set up a few cron scripts to sync media from another server of mine and restart miniDLNA (to rescan) as new media is downloaded etc.
The sync script runs every minute via a freenas cronjob, but I've noticed I've been getting emails each minute as follows:
To: root
Subject: Cron <root@dave-nas> PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bin" /mnt/Vol1/Dave/Scripts/sync.sh
Body: TERM: Undefined variable.
After a quick Google it suggests it is to do with the .profile / .rc files that are processed when a shell is created but I've had a tweak but haven't managed to fix it!
Any suggestions?
NB: The Cron command is: "/mnt/Vol1/Dave/Scripts/sync.sh"
swiss196
After some more investigation I managed to solve this by adding the TERM environment variable to the main crontab file, along with some other existing environment vars (SHELL, PATH).
mount -uw /
#add line to crontab now... (TERM=xterm)
mount -ur /
EDIT: Oops!
Stupidly I forgot that the crontab would get restored on reboot so the extra line added above was lost. Consequently I found a way around this: Instead of adding this to the crontab directly, add "export TERM=xterm;" to your cron command, before the command you wish to execute (in the freeNAS webgui).
export TERM=xterm; tcsh /mnt/Vol1/Dave/Scripts/sync.sh
