WeiserMaster
- Nov 11, 2016
Hi there,
For a while now I've had a cron script which would delete the recycle bin folder on my NAS automatically.
But for whatever reason it doesn't execute the script properly, it will not erase the recycle bin folder and its contents.
This is the original script, which has been working:
And I've tried out several from Google, but I haven't written down which those were.. This is one of those:
I've got one dataset (ds1) in volume1 (vol1), the directory for the pool is /mnt/vol1/ds1.
The user executing the scripts has got full access to everything on the disk, including the recycle bin folder.
I am able to delete files with that user, over the CLI and Windows Explorer.
I've tried running it over the cron tab, manually as root (which not surprisingly didn't work because of permissions) and manually as the user with full access to the volume.
I'm running FreeNAS-9.10.2-U1 (86c7ef5) on ESXi with a H310 in IT mode.
Do you guys know what is going wrong?
Thanks in advance,
WeiserMaster
Edit:
I also get these mails since proxmox writes backups to one of the backup shares, but the script isn't running properly since almost a month ago.
The proxmox backups were set up somewhere around 30th of march, so these shouldn't be the main reason why the backups weren't running. The oldest files in the .recycle folder were from the beginning of March.
#!/bin/sh
find /mnt/ -name ".recycle" > /tmp/list
cat /tmp/list | xargs -I % find %/ -atime +3 -exec rm -rf '{}' \;And I've tried out several from Google, but I haven't written down which those were.. This is one of those:
find /mnt/vol1/*/.recycle/* -atime +3 -delete; find /mnt/vol1/*/.recycle/ -type d -empty -delete,
Thanks in advance,
WeiserMaster
Edit:
Cron <user@nas> PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bin" /mnt/vol1/ds1/emptyrecycle.sh > /dev/null find: /mnt/vol1/ds1/Backups/proxmox/dump: Permission denied
