System randomly rebooting
Sicone
My system has been randomly rebooting for the last coupe of weeks. Having search the forum as best as I can, I have updated from 9.10 to 11.1 u6 but it hasn't resolved the problem.
I can't see anything in /var/log/messages (posted below - I know there are a couple of unreadable sectors but those appeared after the rebooting started happening), there is nothing in the IMPI event log and there doesn't seem to be a consistant time of day that it occurs.
What else I can check?
generate
generate
  • messages.txt
kdragon75
Have you monitored temps?
Chris Moore
Complete hardware description?
Sicone
Full specs:
  • Supermicro X10SLL-F
  • Intel i3-4130
  • 2 * 8Gb Crucial ECC 1600MHz
  • 5 * WD30EZRX WD Green 3TB in RaidZ2
  • 500W Corsair CP-9020059-NA/RF PSU
  • 2xKingston 16gb usb boot drives
Temps do not look out of the ordinary
  • CPU:26c
  • System:24c
  • DIMMA:26c
  • DIMMB:26c
  • HDDs:27-30c
Chris Moore
Was this a new supply to this build?
How long has this been running?
Probably want to address those after the rebooting issue is cleared up.
I have seen bad power supplies cause reboots. That is probably the thing I would look at next. Do you have another power supply that you can test this with by swapping it out?
Sicone
Yes
Since Feb 2015 - Updated to 11.1 U6 on Saturday
Agreed!
Don't have one to hand but I guess this is a good suggestion
Chris Moore
Sicone
Thought I'd come back to mention that my system has been up for just over 2 weeks without any reboots since changing the PSU, so I think it's safe to say it's been resolved
Chris Moore
That is great.
Did you address the hard drive issue yet?
