mrbutterferd
- Aug 6, 2018
Ill Start with specs before the issue just in-case I have something wrong:
I am runing FreeNAS-11.2-BETA2 Build Date: Aug 1, 2018 17:7
Proccessor: AMD FX 8320
Memory: 20GB of DD3
HDD: 4tb Seagates
The issue I am running into is when I try to do large file transfers either to the system or removing from system it will freeze. Ill explain my crash so, windows will report that the network drive has been disconnect and that the local device name is already in use. Then I attempt to go to the ip address that I have setup for it and I will not be able to connect. So I have a monitor connected to the freenas (Because of the on going issues) and the system is in a frozen state so the only way I have found to bring it back is to do a hard reboot and then it is back to normal. I have SSH enable and when this happens I cannot connect either. My network is pretty simple I have a Comcast modem that handles DHCP and I have an enterprise HP switch that the modem connects to and from there all my devices are connected. I do not believe this to be a network issue but I thought I would include it to cover as much basis as I can. If there is a link to a person that has a similar issue that is solve please link and I will delete post and thanks in advance.
Memory: 20GB of DD3
HDD: 4tb Seagates
