System dataset broken and not mounted on pool
viniciusferrao
Hello. It seems that the system dataset in one of my systems is broken. RRD graphics aren't showing up so after debugging the system dataset is the one to blame.
I don't know how to reenable/recover it, but here's the situation:
root@truenas-repos[/tmp]# zfs list -t filesystem | grep -F ".system"
boot-pool/.system                                            698M  24.3G      645M  legacy
boot-pool/.system/configs-40cc91dacae0491e84781ab81ded8ba4  1.89M  24.3G     1.89M  legacy
boot-pool/.system/cores                                       96K  1024M       96K  legacy
boot-pool/.system/ctdb_shared_vol                             96K  24.3G       96K  legacy
boot-pool/.system/glusterd                                    96K  24.3G       96K  legacy
boot-pool/.system/rrd-40cc91dacae0491e84781ab81ded8ba4      41.8M  24.3G     41.8M  legacy
boot-pool/.system/samba4                                     676K  24.3G      676K  legacy
boot-pool/.system/services                                    96K  24.3G       96K  legacy
boot-pool/.system/syslog-40cc91dacae0491e84781ab81ded8ba4   8.26M  24.3G     8.26M  legacy
boot-pool/.system/webui                                       96K  24.3G       96K  legacy
repos0/.system                                               709M  4.02T      645M  legacy
repos0/.system/configs-40cc91dacae0491e84781ab81ded8ba4     2.64M  4.02T     2.64M  legacy
repos0/.system/cores                                         162K  1024M      162K  legacy
repos0/.system/ctdb_shared_vol                               162K  4.02T      162K  legacy
repos0/.system/glusterd                                      162K  4.02T      162K  legacy
repos0/.system/rrd-40cc91dacae0491e84781ab81ded8ba4         49.6M  4.02T     49.6M  legacy
repos0/.system/samba4                                        875K  4.02T      875K  legacy
repos0/.system/services                                      162K  4.02T      162K  legacy
repos0/.system/syslog-40cc91dacae0491e84781ab81ded8ba4      10.1M  4.02T     10.1M  legacy
repos0/.system/webui                                         162K  4.02T      162K  legacy
root@truenas-repos[/tmp]# mount | grep -i var
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
boot-pool/.system on /var/db/system type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/cores on /var/db/system/cores type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/samba4 on /var/db/system/samba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
boot-pool/.system/syslog-40cc91dacae0491e84781ab81ded8ba4 on /var/db/system/syslog-40cc91dacae0491e84781ab81ded8ba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
collectd seems to be crashed:
May 21 21:23:08 truenas-repos systemd[1]: Starting Statistics collection and monitoring daemon...
░░ Subject: A start job for unit collectd.service has begun execution
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit collectd.service has begun execution.
░░ The job identifier is 2550240.
May 21 21:23:08 truenas-repos collectd[2834667]: Configuration file /etc/collectd/collectd.conf is empty.
May 21 21:23:08 truenas-repos collectd[2834667]: Error: Parsing the config file failed!
May 21 21:23:08 truenas-repos systemd[1]: collectd.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit collectd.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
May 21 21:23:08 truenas-repos systemd[1]: collectd.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit collectd.service has entered the 'failed' state with result 'exit-code'.
May 21 21:23:08 truenas-repos systemd[1]: Failed to start Statistics collection and monitoring daemon.
░░ Subject: A start job for unit collectd.service has failed
░░ A start job for unit collectd.service has finished with a failure.
░░ The job identifier is 2550240 and the job result is failed.
Any help is appreciated.
Thanks.
A couple of things you can try...
First, move the system dataset to a different pool (and then back again).
Then restart the collectd service:
service collectd restart
viniciusferrao
How can I do that? I'm running SCALE and I can't see where are the settings for the system dataset.
System Settings | Advanced | Storage ... click Configure...
viniciusferrao
How could I missed that :|
Thank you, I moved to the boot-pool and the moved back to the repos0 pool and collectd is working again, graphics on /reportsdashboard are back but only the ZFS ones, others just show nothing. At least there's no longer an error.
Is there any health check that I can run?
Also the system dataset seems to be correct now:
root@truenas-repos[~]# mount | grep -i var
repos0/.system on /var/db/system type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/cores on /var/db/system/cores type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/samba4 on /var/db/system/samba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/syslog-40cc91dacae0491e84781ab81ded8ba4 on /var/db/system/syslog-40cc91dacae0491e84781ab81ded8ba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/rrd-40cc91dacae0491e84781ab81ded8ba4 on /var/db/system/rrd-40cc91dacae0491e84781ab81ded8ba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/configs-40cc91dacae0491e84781ab81ded8ba4 on /var/db/system/configs-40cc91dacae0491e84781ab81ded8ba4 type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/webui on /var/db/system/webui type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/services on /var/db/system/services type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/glusterd on /var/db/system/glusterd type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/ctdb_shared_vol on /var/db/system/ctdb_shared_vol type zfs (rw,relatime,xattr,noacl,casesensitive)
repos0/.system/cores on /var/lib/systemd/coredump type zfs (rw,relatime,xattr,noacl,casesensitive)
Thanks.
It may take a restart to put everything back... even clearing out the rrd data might be needed, but I would try the reboot first.
viniciusferrao
It was just my affliction. Graphics are gradatively coming back. So it may not even need a reboot.
I think it's fixed.
Thank you so much @sretalla
