i installed syncthing on a 11.3 U1 system, and it seemed fine.
trying to sync data between freenas and a series of desktops (one for now) on a lan
but two issues; one, the freenas server now crashes periodically
and two, the speeds are horrendously slow
checked the syncthing address and it says 'relay client' which according to syncthing is not a good thing, and will cause the slow speeds. which is what i have. but they show no solution
also checked the version numbers; the freenas version is 1.3, the windows version 1.4; those seem to be the latest, at least the latest available. but perhaps the latest available for freenas isnt the latest?
anyone have any suggestions? i tried deinstalling/reinstalling, same issue. opened up upnp like they suggested, no change.
is this plugin just buggy/old? im getting about 1.2 Mibs which is painfully slow, making this useless
and the reboot issue is even worse; what could cause a system reboot when a jail crashes; i am not that familiar with jails but would think they would be isolated from such things.
thanks for any suggestions
