I have the following situation: We have 2 different locations where access to one common fileserver is needed. Between these two sites we have a WAN connection with 5 MBit (symmetric). Our main problem is that we have some large files there and they need to be edited on each site. So I thought of setting up two FreeNAS servers, one at each site and they are synchronized. This would give us enough performance for the 500mb-files (technical CAD). Now my question is whether it is possible to make the two filesystems at each site dependent on each other. So, if a user at the HQ edits a file, another user at the remote site cannot edit this file on his server. So the file should be marked 'read only' on the remote server. By this procedure it would be very simple to prevent inconsistency. After the user at the HQ has finished his work, the file should automatically be synchronized to the remote site and the 'read only'-flag should be unset.
So what I'm searching is a kind of cluster. Is this possible with FreeNAS?
Thank you!
Peter
Thank you!
Peter
