C2Opps
- Jun 11, 2018
Hi All,
Had a look in previous threads on this but either there isn't anything or i'm not using the correct search terms.
In any case I have two FreeNAS systems one at each site that for 1 particular small dataset of ISO's / system tools I would like to do some kind of circular replication.
Data changes on Box1 ISO Dataset would be replicated to Box2 ISO dataset, also if data is changed on Box2 ISO dataset it would be replicated to Box1 ISO dataset.
Both datasets would have the same file structure and so conceivably add ExampleFile1 at site 1, it ends up at site 2 in the same folder then if that file was modified at site 2 it would replicate and over write ExampleFile1 at site 1
This dataset rarely has new things added or removed and data is almost never edited, once we put an ISO into the dataset (on either box) we'd would like it available at the other site within a few hours or a day (not sure yet).
Is it reasonable and safe for the data to setup ZFS replication to do this in both directions (at separate times) and if so are there any issues i should be aware of such as
-Needing to make sure that the replication never overlaps - say a large influx of new data was making replication take a long time in one direction and the replication in the other direction started would it / could it cause an issue or would it be fine
- Needing to do anything clever with regard to the replication / set special options
Many thanks in advance,
C2Opps
C2Opps
