I've upgraded from FreeNAS 9.10 to 11.3 and switched some jails from warden to iocage.
I replicated the warden jails to another server previously and am now trying to recreate the replication to move the iocage jail datasets now instead.
All servers are running FreeNAS 11.3-U5.
source: freenas03.local: vol01/iocage/jails/network253
destination: freenas02.local: vol01/Backups-remote-vm/freenas03/jails/network253
I've tried legacy, ssh and ssh+netcat replication methods.
Naturally the snapshots are not the same, so I want to wipe the old snapshots and move forward with iocage-based snaps only.
When I kick off the replication task manually, I get this error:
which makes sense of course.
When I go into the replication task configuration and check the "
I get this:
Detail:
Keep in mind that the task was previously configured (so I assume there are no nulls in there!)
Any ideas or troubleshooting suggestions appreciated...
For bonus points and admiration... I have three servers so I am replicating the jail datasets on freenas03 to freenas01 and freenas02. I see that FreeNAS has created two additional snapshot tasks for each dataset/replication task... when there is already a top level recursive snapshot task for vol01/iocage. What the heck is going on? Why is FreeNAS proliferating (unnecessary?) snapshot tasks??!!
thanks... Brad
No incremental base on dataset 'vol01/iocage/jails/network253' and replication from scratch is not allowed.which makes sense of course.
Replicate from scratch if incremental is not possible" option,I get this:
[large block] null not allowed.Detail:
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1084, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.7/site-packages/middlewared/service.py", line 402, in update
f'{self._config.namespace}.update', self, self.do_update, [id, data]
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 960, in nf
args, kwargs = clean_and_validate_args(args, kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 918, in clean_and_validate_args
value = attr.clean(args[args_index + i])
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 594, in clean
data[key] = attr.clean(value)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 370, in clean
value = super().clean(value)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 76, in clean
raise Error(self.name, 'null not allowed')
middlewared.schema.Error: [large_block] null not allowedKeep in mind that the task was previously configured (so I assume there are no nulls in there!)
thanks... Brad
