SYBA SY-PEX24028 Dual Port Gigabit Ethernet Network Adapter 10/ 100/ 1000Mbps PCI-Exp
azeous
Dear Gent's can you tell me if this NIC is supported by freenes because I want to use the link aggregation in freenas.
product details :
http://www.sybausa.com/productInfo.php?iid=1291
here is my mother board that I want to add the nic to it & if you can suggest any other NIC that it fully supported by both freenas and my mother board :
Gigabyte EP45T-UD3LR
survive
Behold the Wumpus
Hi azeous,
I always consider it a bad sign when the maker doesn't tell you what the chip the board is based on, that said the NIC uses the RealTek RTL8111E chipset so it should be supported. I can't tell you how it will work with ling aggregation. The SYBA card is PCI-e 1x, so it should work in any PCI-e slot on your board.
-Will
azeous
thanks alot for you replay and I am waiting to test with free NAS ,Why I Choose this mode because it's sheep it cost only $38.
ShaharHD
Re: SYBA SY-PEX24028 Dual Port Gigabit Ethernet Network Adapter 10/ 100/ 1000Mbps PCI
sorry to hijack this thread - but it seems I have a weird issue with this card.
my motherboard doesn't even detect it - I can't see any information of this card in pciconf or devinfo ... but the on-board re0 is detected and working correctly.
tried to disable the on-board from the BIOS, but freebsd just brings it back to life ... and still no PEX24028 detection.
any idea why?
Motherboard: GA-F2A85X-D3H
Please start your own thread if you have a problem and be sure to follow the forum rules and include the appropriate information(you didn't here). It is good forum etiquette to keep the thread to the original topic. Additionally, it is bad ettiquette to resurrect a months old thread.
