Swap dual E5620 for L5630 to save on power?
helloha
Currently running dual E5620 chips with a TDP of 80 watt. Since the CPUs are on idle for most of the time, I was wondering if I could swap them out for two L5630 chips with a TDP of 40 watt to save power. I need two because I need all the memory slots to be populated.
Would this have any effect on power consumption? Or does an idle E5620 use the same power as an idle L5630?
I am running a 10Gbps Chelsio card in this server so if this could be a potential bottleneck it wouldn't be interesting.
Thanks for tips!
K.
Mirfster
Sure if desired and your MB will support it. You will drop in processing power, but I assume you already knew that. I don't think that it will have much of an effect on your 10Gbps NIC (bottleneck wise).
SweetAndLow
Sweet'NASty
At idle it will not change your power consumption very much or at all.
