Hi folks!
Like most of my projects, this one has become something of its own living, breathing organism. I started off on this journey with a $1500 budget and I was simply going to buy a Synology with a Celeron chip so I could let the device handle a plex server and one.. maybe 2 transcodes. Well, I started down the rabbit hole and I emerged with this:
- Superstorage 6047R-E1R24N: 24 Bay SAS3 backplane storage chassis
- Super X9DRi-LN4F+ with 2x E5-2630L Xeons (60 Watt TDP each)
- 128GB 8x 16GB ECC RAM
- LSI 9211-81 (IT mode)
- 2x IBM i340-T4 Quad GB Nics
- 6x Constellation 4TB SAS
- 2x 128GB Adata SSD
I went $50 over budget
I expect this thing to idle around 300 Watts and since it will be replacing multiple workstations in server roles and several network devices... I think my power bill will be about the same. That being said - here is the plan:
1) Configure 2x 120GB SSDs in raid mirror using on-board intel controller
2) Install ESX to USB thumb and boot from that critter
3) Setup ESX to use this new Datastore
4) Install Freenas to this mirror and assign direct access to LSI controller
5) Add constellation drives, setup pools, turn off dedupe, etc...
6) ?
7) Profit!
Now, if it will FreeNAS - I have an additional 2 questions.
1) I am really torn on whether to iSCSI or NFS. This is a "home" use case. I fully expect that 75% of the network data will never leave the chassis. I'll have a few shares (windows destinations) and of course, Plex which will be sent to the physical LAN.
2) Would I gain any benefit from carving up that initial 120GB SSD mirror into a 30GB partition for the FreeNAS datastore and then creating another 90GB (+/-) partition for cacheing, for FreeNAS? This is another spot that I have a disconnect... whether I *need* a ZIL or SLOG in this small of a setup.
Clear as mud? I have attached an image that can maybe, explain a little better than I have above. Additionally - would it be of any benefit to do a build thread for this project.. or has that already been done to death here?
Thanks!
6) ?
7) Profit!
Thanks!
