jgreco
Resident Grinch
- May 29, 2011
The Idea I came up with myself, because I didn't like the active cooler idea. If you seen supermicro shipping that cooler with 1600 CPU in already build server it's easy to put the idea together, that these two will work , but is not something that is documented by them, and here are the too methods I used:
1. I went on their website http://www.supermicro.com/ResourceApps/Heatsink_Matrix.aspx and looked all cpu coolers for socket 2011 and the only option for 1600 was SNK-P0048AP4 not SNK-P0048P. I added picture so you can see yourself.
2. I contacted supermicro to ask them , and they send me this file.Here is the pic of that too.
So these are the only 2 options I know and use to get the ideas for the heatsink for 1620 v2 and non of them indicates the possibility of using passive heatsink for 2u.
Am I missing something ? Was there 3th option I neglected to check ?
Don't know. I walked through what would have probably happened here.
