MarcusW743
- Oct 3, 2018
the NAS I'm going to build needs to live in my bedroom and therefore has to be very quiet. It'll never serve more than 1-2 users at the same time and will be equiped with two 4TB HDDs (mirrored).
Also it should be as cost-effective as possible while being safe (e.g. ECC Memory) and future-proof.
I think that, after multiple days and iterations of Hardware configs and reading the Hardware Guides, I finally have a good starting point for my first FreeNAS setup.
But I still do have some questions and would appreciate if somebody could verify that all of this is actually compatible and meets my requirements.
CPU: Intel Pentium G5500 (Mindfactory) (Specs) - 99,00 EUR
Mainboard: Supermicro MBD-X11SSL-F (Mindfactory) (Specs) - 175,97 EUR
RAM: Kingston 8GB DDR4-2400 ECC DIMM (Mindfactory) - 92,47 EUR
PSU: be-quiet 400W 80+ Gold (Mindfactory) - 58,03 EUR
Case: Nanoxia Deep Silence 4 (Mindfactory) - 61,83 EUR
HDDs: 2x 4TB WD RED (Mindfactory) - 2x 111,70 EUR = 223,40 EUR
10GbE: Pair of Mellanox ConnextX-2 (Ebay) - 69,90 EUR (already bought)
Boot-Stick: 16GB SanDisk USB 3.0 (Mindfactory) - 7,52 EUR
-> Total: 788,12 EUR
I decided to not use the recommended RAM from the verified list of the mainboard because they were nearly 50 EUR more expensive and very hard to get. But using Kingston memory instead shouldn't be an issue, right?
I know that the 400 watt PSU is probably a little bit over-powered but I want to make sure that it will still be powerful enough if all 6 drive bays will be filled one day. Also I hope that this power-supply will be silent enough to not keep me awake.
What do you think about this config? Have I missed something? Will it FreeNAS..?
Or do you know some other Mainboard+CPU config with comparable performance to save a buck?
Thank you in advance!
Marcus Wichelmann
Marcus Wichelmann
