A bit esoteric, but perhaps someone can help out. I am building a server that uses a Supermicro X11SCL-F motherboard in an older 825TW-R700LPB chassis. The chassis contains a BPN-SAS-825TQ backplane.
I'm trying to figure out if it's necessary/desirable/possible to connect the backplane's sideband connector to the MB. The MB manual (https://www.supermicro.com/manuals/motherboard/X11/MNL-2063.pdf) p 47 describes a pair of SGPIO headers and states "The SGPIO headers are used to communicate with the enclosure management chip on the back panel. "
The chassis manual (https://www.supermicro.com/manuals/chassis/2U/SC825.pdf) p. B-5 states " The sideband headers are designated JP51 and JP52. For SES-2 to work properly, you must connect an 8-pin sideband cable. See the table to the right for pin definitions" and then p. B-7 says "This backplane can utilize SGPIO or I2C, which is the default mode and can be used without making changes to your jumpers. The following information describes which jumper must be configured to use SGPIO mode."
So it looks to me like I'd need to set the backplane to SGPIO mode, and then these would be connectable, but the pinouts don't seem to match at all. Is the "8-pin sideband cable" a specific cable for this purpose? Do I need to try to figure out the pinout mismatch and make my own cable (I can do it, but that seems.... odd to make my own cables).
More fundamentally, what purpose does this sideband connection serve? I saw in the FreeNAS manual, section 9.3 the following: "Beginning with version 9.2.1, FreeNAS® provides a graphical screen for configuring an IPMI interface. This screen will only appear if the system hardware includes a Baseboard Management Controller (BMC). " Is this connection required for the IPMI screen to work? In any event, Is this all necessary? Will it benefit me in some way? Should I just skip it?
If it matters, the machine will be a pure NAS, running FreeNAS on bare metal, no jails, no VMs living on the machine, just pure data storage.
Thanks!
Thanks!
