DearestDreamer
- Nov 28, 2015
I seem to have a weird issue that doesn’t make much sense to me. My 836BA-R920b chassis’ front panel has a LED that the manual labels as “Power Fail: Indicates a power supply has failed”. My server is connected to a 1000 watt UPS. I have the X10SRL-F motherboard and yes the chassis revision is ‘M’.
The LED is red – not blinking, but constantly illuminated as red after startup.
I checked the following:
1. Both PSUs have a green light in the back, I assume this means they’re working
2. I unplugged the top PSU and the server started from just the bottom one
3. I unplugged the bottom PSU and the server started from just the top one
4. I plugged both PSUs directly into the wall, instead of of the UPS
5. Simulated a power failure by unplugging one power cord and I did hear the internal switch to the other power supply, so I think the redundancy works just fine
All of this appears to work, the server is powered on and there’s “no issues”, but the ‘Power Fail’ LED is red. What’s going on here? How should I troubleshoot this? Could my front panel be broken (All the other LEDs work properly)? Do I have to enable the other PSU in the BIOS?
In IPMI I don't see a red exclamation or some alert about the PSU or power fail:
I also noticed through IPMI that I only see “PS1”, is this correct?
Here's some more images that might help understand what my setup looks like currently. While it looks like I have SATA drives installed, it's wrong. I also don't have any other drives installed, so the HBAs are just connected to the backplane through SFF8087, that's it.
Here's my build thread for reference: https://forums.freenas.org/index.ph...and-x9srh-7f-o-26tb-raidz3.39556/#post-245220
Any help would really be appreciated, since I don't know if the LED should be red normally or if I might have some kind of broken front panel that I need to RMA?
