I've run out of physical space, and have been looking into the supermicro chassis. I'm having a lot of analysis paralysis, and all this business grade gear is completely new to me.
I live in Australia which makes sourcing a suitable case difficult and expensive since shipping is $400US. I keep leaning towards the 36 bay cse-847 chassis, and the only real option seems to be this, as they said they don't sell the barebones case (with vertical half-height slots).
This is a backup pc, which is only turned on every couple of weeks to sync. My current tower only has two expansions cards, the hba and a 40gbe NIC.
What options should i change within the listed configuration?
I figure i want atleast 4x the processor power of my presently bottlenecked 2c2t celeron g3930. So perhaps ask for either dual 6 core v2 cpu's (E5-2620?), or a single 8/10 core v2 cpu?
32gb of ram sounds like enough for a backup pc, even though it's listed with 64gb. Should I go single cpu with less ram, or stick to smaller dual cpu's with 64gb?
Should I be asking for the smaller 920w model quiet PSU?
Should I change anything else? Should i just go a cheap consumer board with an older gen ryzen given their insane value/$ these days? I realize these cases are very loud, and will do what i can to quieten it and monitor the effects on hdd temps.
Supermicro 36 Bay LFF 6Gbp FREENAS Storage Server Xeon E5-2620 12 core 64GB Rail | eBay
Find many great new & used options and get the best deals for Supermicro 36 Bay LFF 6Gbp FREENAS Storage Server Xeon E5-2620 12 core 64GB Rail at the best online prices at eBay!
www.ebay.com.au
