Mirfster
- Oct 2, 2015
Um, Yes and No... :)So then based on that info, something like this should do out of the box. Maybe more RAM and obviously HDDs.
http://www.ebay.com/itm/Dell-PowerE...088919?hash=item3a945ae897:g:BdQAAOSwjyVT0D5l
I am very familiar with that seller and their stuff is top notch. At least two (if not three of my systems came from them).
With that said:
- The Perc H700 is not going to work. It can't be cross-flashed to JBOD/IT Mode; so it is a waste and you would have to replace it with a card that could be (IBM M1015, Perc H200, LSI 9211 etc.)
- They are only providing one CPU; which more than likely means that they are not including the heatsink for a 2nd CPU. Then you would have to purchase that later if you decided to add another CPU
- It only has 8 GB of RAM (not the greatest; especially for the price)
- Doesn't really say if it includes the drive tray (and screws, you always want the screws too). While picture shows them, the description does not..
- Overall seems a bit pricey for what they are including
- Has the H200 already, so all you have to do is cross-flash it (maybe if you ask they will even cross-flash it for you; not really needed though since it is pretty simple)
- Has two CPUs with heatsinks
- Has 6 times the RAM
- Does include the trays (still ask and make sure you get the screws as well)
- Overall same price as the one linked (with shipping and all)
- Comes with rails (good if you are rack mounting)
- This is a "Turn Key" solution IMHO
Edit: I just looked at the pictures as well. In the 3rd one it appears as if the H200 they are including is the "Mezzanine" model (connects directly to the Motherboard instead of using a PCIe Slot). That is a nice surprise, since alone that card is ~$130.00 itself. I use them and have bought most of mine afterwards. Example: search eBay for the item which is part number : 85M9R
