Supermicro and LSI not playing nice.
kdragon75
I am building a new to me NAS and after exchanging motherboards twice... I have what should be a working system. The odd thing is that ocasonly the system hangs while detecting my disks and will eventual boot but none of my SATA disks are present. If I run "camcontrol rescan all" It hangs again and does nothing. I do have 4 SAS SSDs that detect and work fine every time.
Motherboard: X8SIL-f
CPU: Xeon X3440
RAM: 12GB DDR3 R-DIMM
HBA: Dell Perc H310 cross flashed to LSI 9211-8i 20.00.07
Cassis/Backplane: CSE-826E1-R800LPB
FreeNAS 11.1-U2
dmesg output:
TempNAS# dmesg
Copyright (c) 1992-2017 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
		The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 11.1-STABLE #0 r321665+de6be8c8d30(freenas/11.1-stable): Tue Feb 20 02:3																																							 8:09 UTC 2018
	root@gauntlet:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/																																							 _BE/os/sys/FreeNAS.amd64 amd64
FreeBSD clang version 5.0.0 (tags/RELEASE_500/final 312559) (based on LLVM 5.0.0																																							 svn)
CPU: Intel(R) Xeon(R) CPU		   X3440  @ 2.53GHz (2533.39-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x106e5  Family=0x6  Model=0x1e  Stepping=5
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C																																							 MOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x98e3fd<SSE3,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM																																							 ,SSE4.1,SSE4.2,POPCNT>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,VPID
  TSC: P-state invariant, performance statistics
real memory  = 13958643712 (13312 MB)
avail memory = 12400365568 (11825 MB)
Event timer "LAPIC" quality 100
ACPI APIC Table: <052710 APIC1450>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 hardware threads
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20170																																							 728/tbfadt-748)
ioapic0: Changing APIC ID to 8
ioapic0 <Version 2.0> irqs 0-23 on motherboard
SMP: AP CPU #1 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #5 Launched!
Timecounter "TSC-low" frequency 1266693226 Hz quality 1000
random: entropy device external interface
kbd1 at kbdmux0
nexus0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: No ACE support.
acpi0: <SMCI > on motherboard
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pcib0: _OSC returned error 0x10
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 3.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 5.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
pcib3: [GIANT-LOCKED]
pci3: <ACPI PCI bus> on pcib3
mps0: <Avago Technologies (LSI) SAS2008> port 0xc000-0xc0ff mem 0xfb3b0000-0xfb3																																							 bffff,0xfb3c0000-0xfb3fffff irq 16 at device 0.0 on pci3
mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,Even																																							 tReplay,HostDisc>
pcib4: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
pcib4: [GIANT-LOCKED]
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0
pcib5: [GIANT-LOCKED]
pci5: <ACPI PCI bus> on pcib5
ehci1: <Intel PCH USB 2.0 controller USB-A> mem 0xfb2fa000-0xfb2fa3ff irq 23 at																																							  device 29.0 on pci0
pcib6: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci6: <ACPI PCI bus> on pcib6
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Ibex Peak AHCI SATA controller> port 0xa400-0xa407,0xac00-0xac03,0																																							 xa880-0xa887,0xa800-0xa803,0xa480-0xa49f mem 0xfb2f8000-0xfb2f87ff irq 19 at dev																																							 ice 31.2 on pci0
ahci0: AHCI v1.30 with 6 3Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff on isa0
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
mps0: SAS Address for SATA device = 65405f1899b6ac82
mps0: SAS Address for SATA device = 3b403b1b99b8a984
mps0: SAS Address for SATA device = 3c66511f99b6ac8a
mps0: SAS Address for SATA device = db424b1b99b8a986
mps0: SAS Address for SATA device = 4f49631b99b8a986
mps0: SAS Address for SATA device = d060641b99b8a986
mps0: SAS Address for SATA device = d655421b99b8a972
mps0: SAS Address from SATA device = 65405f1899b6ac82
mps0: SAS Address from SATA device = 3b403b1b99b8a984
mps0: SAS Address from SATA device = 3c66511f99b6ac8a
mps0: SAS Address from SATA device = db424b1b99b8a986
mps0: SAS Address from SATA device = 4f49631b99b8a986
mps0: SAS Address from SATA device = d060641b99b8a986
mps0: SAS Address from SATA device = d655421b99b8a972
ugen1.2: <vendor 0x8087 product 0x0020> at usbus1
uhub2 on uhub0
uhub2: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on usbus																																							 1
ugen0.2: <vendor 0x8087 product 0x0020> at usbus0
uhub3 on uhub1
uhub3: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on usbus																																							 0
uhub3: 6 ports with 6 removable, self powered
uhub2: 8 ports with 8 removable, self powered
ugen0.3: <Winbond Electronics Corp Hermon USB hidmouse Device> at usbus0
ukbd0 on uhub3
ukbd0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10																																							 /0.01, addr 3> on usbus0
kbd2 at ukbd0
ugen1.3: <Plus More Enterprise LTD. USB-compliant keyboard> at usbus1
ukbd1 on uhub2
ukbd1: <Plus More Enterprise LTD. USB-compliant keyboard, class 0/0, rev 1.10/1.																																							 00, addr 3> on usbus1
kbd3 at ukbd1
ugen1.4: <SanDisk Cruzer Fit> at usbus1
umass0 on uhub2
umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/1.22, addr 4> on usbus1
umass0:  SCSI over Bulk-Only; quirks = 0xc100
umass0:8:0: Attached to scbus8
random: unblocking device.
run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config mps_st																																							 artup
run_interrupt_driven_hooks: still waiting after 120 seconds for xpt_config mps_s																																							 tartup
		(probe10:mps0:0:28:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 16																																							 4 Aborting command 0xfffffe0001372740
mps0: Sending reset from mpssas_send_abort for target ID 28
		(probe9:mps0:0:27:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 163																																							  Aborting command 0xfffffe00013725f0
mps0: Sending reset from mpssas_send_abort for target ID 27
		(probe7:mps0:0:25:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 161																																							  Aborting command 0xfffffe0001372350
mps0: Sending reset from mpssas_send_abort for target ID 25
		(probe5:mps0:0:30:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 159																																							  Aborting command 0xfffffe00013720b0
mps0: Sending reset from mpssas_send_abort for target ID 30
		(probe4:mps0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 158																																							  Aborting command 0xfffffe0001371f60
mps0: Sending reset from mpssas_send_abort for target ID 29
		(probe2:mps0:0:23:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 156																																							  Aborting command 0xfffffe0001371cc0
mps0: Sending reset from mpssas_send_abort for target ID 23
		(probe1:mps0:0:24:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 155																																							  Aborting command 0xfffffe0001371b70
mps0: Sending reset from mpssas_send_abort for target ID 24
mps0: (probe1:mps0:0:24:0): INQUIRY. CDB: 12 00 00 00 24 00
Unfreezing devq for target ID 24
mps0: run_interrupt_driven_hooks: still waiting after 180 seconds for(probe4:mps																																							 0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00
Unfreezing devq for target ID 29
(probe4:mps0:0:29:0): CAM status: Command timeout
(probe4: xpt_config
mps0:0:mps0: Unfreezing devq for target ID 30
(probe1:mps0:0:24:0): CAM status: Command timeout
(probe1:mps0:0:mps0: 24:0): Retrying command
29:0): Retrying command
Unfreezing devq for target ID 25
mps0: (probe7:mps0:0:25:0): CAM status: Command timeout
(probe7:Unfreezing devq for target ID 27
mps0: Unfreezing devq for target ID 28
mps0:0:25:0): Retrying command
(probe9:mps0:0:27:0): CAM status: Command timeout
(probe9:mps0:0:27:0): Retrying command
(probe5:mps0:0:30:0): CAM status: Command timeout
(probe5:mps0:0:30:0): Retrying command
(probe10:mps0:0:28:0): CAM status: Command timeout
(probe10:mps0:0:28:0): Retrying command
mps0: (probe2:mps0:0:23:0): INQUIRY. CDB: 12 00 00 00 24 00
Unfreezing devq for target ID 23
(probe2:mps0:0:23:0): CAM status: Command timeout
(probe2:mps0:0:23:0): Retrying command
run_interrupt_driven_hooks: still waiting after 240 seconds for (probe5:mps0:0:3																																							 0:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 214 Aborting command 0xffff																																							 fe00013768e0
 xpt_config
		(probe9:mps0:0:27:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 213																																							  Aborting command 0xfffffe0001376790
		(probe7:mps0:0:25:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 212																																							  Aborting command 0xfffffe0001376640
		(probe4:mps0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 211																																							  Aborting command 0xfffffe00013764f0
		(probe1:mps0:0:24:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 210																																							  Aborting command 0xfffffe00013763a0
		(probe10:mps0:0:28:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 21																																							 5 Aborting command 0xfffffe0001376a30
mps0: (probe4:mps0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00
mps0: (probe4:mps0:0:29:0): CAM status: Command timeout
(probe1:mps0:0:mps0: Unfreezing devq for target ID 25
mps0: Unfreezing devq for target ID 27
mps0: (probe4:Unfreezing devq for target ID 28
mps0:0:29:0): Retrying command
(probe7:mps0:0:25:0): Retrying command
(probe9:(probe10:mps0:0:28:0): CAM status: Command timeout
		(probe2:mps0:0:23:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 216																																							  Aborting command 0xfffffe0001376b80
run_interrupt_driven_hooks: still waiting after 300 seconds for xpt_config
		(probe5:mps0:0:30:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 219																																							  Aborting command 0xfffffe0001376f70
		(probe1:mps0:0:24:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 218																																							  Aborting command 0xfffffe0001376e20
		(probe4:mps0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 217																																							  Aborting command 0xfffffe0001376cd0
		(probe9:mps0:0:27:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 222																																							  Aborting command 0xfffffe0001377360
		(probe10:mps0:0:28:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 22																																							 1 Aborting command 0xfffffe0001377210
		(probe7:mps0:0:25:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 220																																							  Aborting command 0xfffffe00013770c0
(probe4:mps0: Unfreezing devq for target ID 25
mps0: mps0:0:29:0): Retrying command
(probe1:mps0:0:24:0): (probe7:mps0:0:25:0): CAM status: Command timeout
Retrying command
mps0: (probe9:mps0:0:27:0): INQUIRY. CDB: 12 00 00 00 24 00
		(probe2:mps0:0:23:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 223																																							  Aborting command 0xfffffe00013774b0
		(probe4:mps0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 224																																							  Aborting command 0xfffffe0001377600
		(probe5:mps0:0:30:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 227																																							  Aborting command 0xfffffe00013779f0
		(probe1:mps0:0:24:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 226																																							  Aborting command 0xfffffe00013778a0
		(probe7:mps0:0:25:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 225																																							  Aborting command 0xfffffe0001377750
		(probe10:mps0:0:28:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 22																																							 8 Aborting command 0xfffffe0001377b40
(probe4:mps0:0:29:0): Retrying command
(probe1:Unfreezing devq for target ID 30
mps0: mps0:0:24:0): Retrying command
		(probe9:mps0:0:27:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 229																																							  Aborting command 0xfffffe0001377c90
		(probe2:mps0:0:23:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 230																																							  Aborting command 0xfffffe0001377de0
		(probe1:mps0:0:24:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 232																																							  Aborting command 0xfffffe0001378080
		(probe4:mps0:0:29:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 231																																							  Aborting command 0xfffffe0001377f30
		(probe10:mps0:0:28:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 23																																							 5 Aborting command 0xfffffe0001378470
		(probe7:mps0:0:25:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 234																																							  Aborting command 0xfffffe0001378320
		(probe5:mps0:0:30:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 233																																							  Aborting command 0xfffffe00013781d0
(probe1:mps0:0:24:0): Error 5, Retries exhausted
(probe4:mps0:0:29:0): Error 5, Retries exhausted
mps0: (probe5:mps0:0:30:0): INQUIRY. CDB: 12 00 00 00 24 00
mps0: (probe7:mps0:0:25:0): INQUIRY. CDB: 12 00 00 00 24 00
(probe7:mps0:0:25:0): Error 5, Retries exhausted
(probe5:mps0:0:30:0): Error 5, Retries exhausted
(probe10:mps0:0:28:0): Error 5, Retries exhausted
		(probe9:mps0:0:27:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 236																																							  Aborting command 0xfffffe00013785c0
(probe9:mps0:0:27:0): Error 5, Retries exhausted
		(probe2:mps0:0:23:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 237																																							  Aborting command 0xfffffe0001378710
(probe2:mps0:0:23:0): Error 5, Retries exhausted
da0 at mps0 bus 0 scbus0 target 10 lun 0
da1 at mps0 bus 0 scbus0 target 15 lun 0
da0: <IBM-SSG HSNX400 A3A0> Fixed Direct Access SPC-4 SCSI device
da0: Serial Number --------
da0: 300.000MB/s transfers
da0: Command Queueing enabled
da0: 381554MB (781422768 512 byte sectors)
da1: <IBM-SSG HSNX400 A3A0> Fixed Direct Access SPC-4 SCSI device
da1: Serial Number --------
da1: 300.000MB/s transfers
da1: Command Queueing enabled
da1: 381554MB (781422768 512 byte sectors)
da2 at mps0 bus 0 scbus0 target 19 lun 0
da3 at mps0 bus 0 scbus0 target 20 lun 0
da2: <IBM-SSG HSNX400 A3A0> Fixed Direct Access SPC-4 SCSI device
da2: Serial Number --------
da2: 300.000MB/s transfersda3: <IBM-SSG HSNX400 A3A0> Fixed Direct Access SPC-4																																							  SCSI device
da2: Command Queueing enabled
da3: Serial Number --------
da3: 300.000MB/s transfers
da3: Command Queueing enabled
da3: 381554MB (781422768 512 byte sectors)
da4 at umass-sim0 bus 0 scbus8 target 0 lun 0
da4: <SanDisk Cruzer Fit 1.22> Removable Direct Access SPC-3 SCSI device
da4: Serial Number --------
da4: 40.000MB/s transfers
da4: 7633MB (15633408 512 byte sectors)
da4: quirks=0x2<NO_6_BYTE>
da2: 381554MB (781422768 512 byte sectors)
ses0 at mps0 bus 0 scbus0 target 22 lun 0
ses0: <LSILOGIC SASX28 A.0 9> Fixed Enclosure Services SCSI-3 device
ses0: 300.000MB/s transfers
ses0: Command Queueing enabled
ses0: SCSI-3 ENC Device
ses0: da0,pass0: Element descriptor: 'SLOT 000'
ses0: da0,pass0: SAS Device Slot Element: 1 Phys at Slot 0, Not All Phys
ses0:  phy 0: SAS device type 1 id 4
ses0:  phy 0: protocols: Initiator( None ) Target( SSP )
ses0:  phy 0: parent 500304800031e77f addr 5000cca0130b5585
ses0: da3,pass3: Element descriptor: 'SLOT 003'
ses0: da3,pass3: SAS Device Slot Element: 1 Phys at Slot 3, Not All Phys
ses0:  phy 0: SAS device type 1 id 7
ses0:  phy 0: parent 500304800031e77f addr 5000cca0130bebc1
ses0: da1,pass1: Element descriptor: 'SLOT 006'
ses0: da1,pass1: SAS Device Slot Element: 1 Phys at Slot 6, Not All Phys
ses0:  phy 0: SAS device type 1 id 10
ses0:  phy 0: parent 500304800031e77f addr 5000cca01307e645
ses0: da2,pass2: Element descriptor: 'SLOT 009'
ses0: da2,pass2: SAS Device Slot Element: 1 Phys at Slot 9, Not All Phys
ses0:  phy 0: SAS device type 1 id 13
ses0:  phy 0: parent 500304800031e77f addr 5000cca01308660d
Trying to mount root from zfs:freenas-boot/ROOT/11.1-U2 []...
module_register_init: MOD_LOAD (vmm, 0xffffffff8281e400, 0) error 6
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<IN																																							 T,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/																																							 48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
(USB, VGA, Network lines removed)
LSI card as shown by lspci:
03:00.0 Serial Attached SCSI controller: LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03)
It seems like cold boots in usually works while warm boots are tend to not work. At this point with my limited knowledge, it seems like a bad interaction with the LSI and backplane and SATA disks..o_O
Chris Moore
Why don't you put all the drives on the SAS controller?
kdragon75
I guess I didn't explicitly say, but they are. The backplane is connected to the 9211-i8 via SFF-8087 to SFF-8087.
