cuvy
- Jun 12, 2015
Hi there,
I search on the forum to figure out what my problems is but to be honest I'm not sure what I'm looking at. Perhaps some tips or pointers will help. Here is the output:
I understand the "CAM status: SCSI Status Error" from da40, da52 and da56 might indicate those drives "might" be faulty. What I struggling with is the "pass37:mps0:0:80:0" log entries. What is it and what could it mean?
Thank you!
Hardware:
FreeNAS-9.3-STABLE-201505130355;
RAIDZ2 (5x 9x3TB);
Intel(R) Xeon(R) CPU E5-2609 0 @ 2.40GHz;
34GB RAM
Motherboard: X9DRD-iF
HBA: SAS2008 PCI-Express Fusion-MPT SAS-2
(noperiph:mps0:0:4294967295:0): SMID 110 Aborting command 0xffffff8000b18ab0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 282 command timeout cm 0xffffff8000b12950 ccb 0xfffffe0018030800 (noperiph:mps0:0:4294967295:0): SMID 111 Aborting command 0xffffff8000b12950 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 301 command timeout cm 0xffffff8000b141a8 ccb 0xfffffe0018030800 (noperiph:mps0:0:4294967295:0): SMID 112 Aborting command 0xffffff8000b141a8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 583 command timeout cm 0xffffff8000b2aaf8 ccb 0xfffffe001807e800 (noperiph:mps0:0:4294967295:0): SMID 113 Aborting command 0xffffff8000b2aaf8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 573 command timeout cm 0xffffff8000b29e28 ccb 0xfffffe001807e800 (noperiph:mps0:0:4294967295:0): SMID 114 Aborting command 0xffffff8000b29e28 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 994 command timeout cm 0xffffff8000b4b990 ccb 0xfffffe001806e000 (noperiph:mps0:0:4294967295:0): SMID 115 Aborting command 0xffffff8000b4b990 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 450 command timeout cm 0xffffff8000b20090 ccb 0xfffffe07187b9800 (noperiph:mps0:0:4294967295:0): SMID 116 Aborting command 0xffffff8000b20090 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 646 command timeout cm 0xffffff8000b2fbb0 ccb 0xfffffe07187b9800 (noperiph:mps0:0:4294967295:0): SMID 117 Aborting command 0xffffff8000b2fbb0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 727 command timeout cm 0xffffff8000b36378 ccb 0xfffffe07187b9800 (noperiph:mps0:0:4294967295:0): SMID 118 Aborting command 0xffffff8000b36378 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 812 command timeout cm 0xffffff8000b3d060 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 119 Aborting command 0xffffff8000b3d060 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 982 command timeout cm 0xffffff8000b4aa30 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 120 Aborting command 0xffffff8000b4aa30 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 480 command timeout cm 0xffffff8000b22700 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 1 Aborting command 0xffffff8000b22700 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 585 command timeout cm 0xffffff8000b2ad88 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 2 Aborting command 0xffffff8000b2ad88 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 600 command timeout cm 0xffffff8000b2c0c0 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 3 Aborting command 0xffffff8000b2c0c0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 774 command timeout cm 0xffffff8000b39fb0 ccb 0xfffffe0018035000 (noperiph:mps0:0:4294967295:0): SMID 4 Aborting command 0xffffff8000b39fb0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 224 command timeout cm 0xffffff8000b0df00 ccb 0xfffffe0018035000 (noperiph:mps0:0:4294967295:0): SMID 5 Aborting command 0xffffff8000b0df00 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 209 command timeout cm 0xffffff8000b0cbc8 ccb 0xfffffe0018035000 (noperiph:mps0:0:4294967295:0): SMID 6 Aborting command 0xffffff8000b0cbc8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 878 command timeout cm 0xffffff8000b424f0 ccb 0xfffffe0018035000 (noperiph:mps0:0:4294967295:0): SMID 7 Aborting command 0xffffff8000b424f0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 907 command timeout cm 0xffffff8000b44a18 ccb 0xfffffe000fff6800 (noperiph:mps0:0:4294967295:0): SMID 8 Aborting command 0xffffff8000b44a18 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 829 command timeout cm 0xffffff8000b3e628 ccb 0xfffffe000fff6800 (noperiph:mps0:0:4294967295:0): SMID 9 Aborting command 0xffffff8000b3e628 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 396 command timeout cm 0xffffff8000b1bb60 ccb 0xfffffe000fff6800 (noperiph:mps0:0:4294967295:0): SMID 10 Aborting command 0xffffff8000b1bb60 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 504 command timeout cm 0xffffff8000b245c0 ccb 0xfffffe000fff6800 (noperiph:mps0:0:4294967295:0): SMID 11 Aborting command 0xffffff8000b245c0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 602 command timeout cm 0xffffff8000b2c350 ccb 0xfffffe000ff93800 (noperiph:mps0:0:4294967295:0): SMID 12 Aborting command 0xffffff8000b2c350 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 129 command timeout cm 0xffffff8000b06548 ccb 0xfffffe000ff93800 (noperiph:mps0:0:4294967295:0): SMID 13 Aborting command 0xffffff8000b06548 (da40:mps0:0:87:0): READ. CDB: 28 00 9d bd 1c f0 00 00 e0 00 length 114688 SMID 618 terminated ioc 804b scsi 0 state c xfer 0 (da40:mps0:0:87:0): READ. CDB: 28 00 9d bd 1c f0 00 00 e0 00 (da40:mps0:0:87:0): CAM status: SCSI Status Error (da40:mps0:0:87:0): SCSI status: Check Condition (da40:mps0:0:87:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) (da40:mps0:0:87:0): Retrying command (per sense data) (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 662 command timeout cm 0xffffff8000b31030 ccb 0xfffffe0018022000 (noperiph:mps0:0:4294967295:0): SMID 14 Aborting command 0xffffff8000b31030 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 888 command timeout cm 0xffffff8000b431c0 ccb 0xfffffe0018022000 (noperiph:mps0:0:4294967295:0): SMID 15 Aborting command 0xffffff8000b431c0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 866 command timeout cm 0xffffff8000b41590 ccb 0xfffffe0018022000 (noperiph:mps0:0:4294967295:0): SMID 16 Aborting command 0xffffff8000b41590 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 311 command timeout cm 0xffffff8000b14e78 ccb 0xfffffe0018080800 (noperiph:mps0:0:4294967295:0): SMID 17 Aborting command 0xffffff8000b14e78 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 545 command timeout cm 0xffffff8000b27a48 ccb 0xfffffe0018080800 (noperiph:mps0:0:4294967295:0): SMID 18 Aborting command 0xffffff8000b27a48 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 674 command timeout cm 0xffffff8000b31f90 ccb 0xfffffe01a7b71000 (noperiph:mps0:0:4294967295:0): SMID 19 Aborting command 0xffffff8000b31f90 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 256 command timeout cm 0xffffff8000b10800 ccb 0xfffffe01a7b71000 (noperiph:mps0:0:4294967295:0): SMID 20 Aborting command 0xffffff8000b10800 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 630 command timeout cm 0xffffff8000b2e730 ccb 0xfffffe000ffbd800 (noperiph:mps0:0:4294967295:0): SMID 21 Aborting command 0xffffff8000b2e730 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 358 command timeout cm 0xffffff8000b18ab0 ccb 0xfffffe000ffbd800 (noperiph:mps0:0:4294967295:0): SMID 22 Aborting command 0xffffff8000b18ab0 (da56:mps0:0:108:0): READ. CDB: 28 00 a9 62 8c c0 00 00 e0 00 length 114688 SMID 243 terminated ioc 804b scsi 0 state c xfer 0 (da56:mps0:0:108:0): READ. CDB: 28 00 a9 62 8c c0 00 00 e0 00 (da56:mps0:0:108:0): CAM status: SCSI Status Error (da56:mps0:0:108:0): SCSI status: Check Condition (da56:mps0:0:108:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) (da56:mps0:0:108:0): Retrying command (per sense data) (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 812 command timeout cm 0xffffff8000b3d060 ccb 0xfffffe0018076000 (noperiph:mps0:0:4294967295:0): SMID 23 Aborting command 0xffffff8000b3d060 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 335 command timeout cm 0xffffff8000b16d38 ccb 0xfffffe0018076000 (noperiph:mps0:0:4294967295:0): SMID 24 Aborting command 0xffffff8000b16d38 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 944 command timeout cm 0xffffff8000b47980 ccb 0xfffffe0018076000 (noperiph:mps0:0:4294967295:0): SMID 25 Aborting command 0xffffff8000b47980 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 728 command timeout cm 0xffffff8000b364c0 ccb 0xfffffe07187b5800 (noperiph:mps0:0:4294967295:0): SMID 26 Aborting command 0xffffff8000b364c0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 832 command timeout cm 0xffffff8000b3ea00 ccb 0xfffffe07187b5800 (noperiph:mps0:0:4294967295:0): SMID 27 Aborting command 0xffffff8000b3ea00 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 635 command timeout cm 0xffffff8000b2ed98 ccb 0xfffffe0018042000 (noperiph:mps0:0:4294967295:0): SMID 28 Aborting command 0xffffff8000b2ed98 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 624 command timeout cm 0xffffff8000b2df80 ccb 0xfffffe0018042000 (noperiph:mps0:0:4294967295:0): SMID 29 Aborting command 0xffffff8000b2df80 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 845 command timeout cm 0xffffff8000b3faa8 ccb 0xfffffe0018042000 (noperiph:mps0:0:4294967295:0): SMID 30 Aborting command 0xffffff8000b3faa8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 829 command timeout cm 0xffffff8000b3e628 ccb 0xfffffe000fff4000 (noperiph:mps0:0:4294967295:0): SMID 31 Aborting command 0xffffff8000b3e628 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 488 command timeout cm 0xffffff8000b23140 ccb 0xfffffe000fff4000 (noperiph:mps0:0:4294967295:0): SMID 32 Aborting command 0xffffff8000b23140 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 148 command timeout cm 0xffffff8000b07da0 ccb 0xfffffe074c920800 (noperiph:mps0:0:4294967295:0): SMID 33 Aborting command 0xffffff8000b07da0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 393 command timeout cm 0xffffff8000b1b788 ccb 0xfffffe074c920800 (noperiph:mps0:0:4294967295:0): SMID 34 Aborting command 0xffffff8000b1b788 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 266 command timeout cm 0xffffff8000b114d0 ccb 0xfffffe074c920800 (noperiph:mps0:0:4294967295:0): SMID 35 Aborting command 0xffffff8000b114d0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 716 command timeout cm 0xffffff8000b35560 ccb 0xfffffe074c920800 (noperiph:mps0:0:4294967295:0): SMID 36 Aborting command 0xffffff8000b35560 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 410 terminated ioc 804b scsi 0 state c xfer 0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 01 00 4f 00 c2 00 b0 00 length 512 SMID 812 terminated ioc 804b scsi 0 state c xfer 0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 813 terminated ioc 804b scsi 0 state c xfer 0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 325 command timeout cm 0xffffff8000b16068 ccb 0xfffffe02b95e6000 (noperiph:mps0:0:4294967295:0): SMID 37 Aborting command 0xffffff8000b16068 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 541 command timeout cm 0xffffff8000b27528 ccb 0xfffffe02b95e6000 (noperiph:mps0:0:4294967295:0): SMID 38 Aborting command 0xffffff8000b27528 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 133 command timeout cm 0xffffff8000b06a68 ccb 0xfffffe02b95e6000 (noperiph:mps0:0:4294967295:0): SMID 39 Aborting command 0xffffff8000b06a68 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 365 command timeout cm 0xffffff8000b193a8 ccb 0xfffffe000ffcb800 (noperiph:mps0:0:4294967295:0): SMID 40 Aborting command 0xffffff8000b193a8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 729 command timeout cm 0xffffff8000b36608 ccb 0xfffffe000ffcb800 (noperiph:mps0:0:4294967295:0): SMID 41 Aborting command 0xffffff8000b36608 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 921 command timeout cm 0xffffff8000b45c08 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 42 Aborting command 0xffffff8000b45c08 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 402 command timeout cm 0xffffff8000b1c310 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 43 Aborting command 0xffffff8000b1c310 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 257 command timeout cm 0xffffff8000b10948 ccb 0xfffffe0018033800 (noperiph:mps0:0:4294967295:0): SMID 44 Aborting command 0xffffff8000b10948 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 1017 command timeout cm 0xffffff8000b4d708 ccb 0xfffffe01a7b63800 (noperiph:mps0:0:4294967295:0): SMID 45 Aborting command 0xffffff8000b4d708 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 894 command timeout cm 0xffffff8000b43970 ccb 0xfffffe01a7b63800 (noperiph:mps0:0:4294967295:0): SMID 46 Aborting command 0xffffff8000b43970 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 512 command timeout cm 0xffffff8000b25000 ccb 0xfffffe000fff5800 (noperiph:mps0:0:4294967295:0): SMID 47 Aborting command 0xffffff8000b25000 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 211 command timeout cm 0xffffff8000b0ce58 ccb 0xfffffe000fff5800 (noperiph:mps0:0:4294967295:0): SMID 48 Aborting command 0xffffff8000b0ce58 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 779 command timeout cm 0xffffff8000b3a618 ccb 0xfffffe000ffd2800 (noperiph:mps0:0:4294967295:0): SMID 49 Aborting command 0xffffff8000b3a618 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 907 command timeout cm 0xffffff8000b44a18 ccb 0xfffffe000ffd2800 (noperiph:mps0:0:4294967295:0): SMID 50 Aborting command 0xffffff8000b44a18 (da40:mps0:0:87:0): READ. CDB: 28 00 c2 c3 05 80 00 00 e8 00 length 118784 SMID 827 terminated ioc 804b scsi 0 state c xfer 0 (da40:mps0:0:87:0): READ. CDB: 28 00 c2 c3 05 80 00 00 e8 00 (da40:mps0:0:87:0): CAM status: SCSI Status Error (da40:mps0:0:87:0): SCSI status: Check Condition (da40:mps0:0:87:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) (da40:mps0:0:87:0): Retrying command (per sense data) (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 831 command timeout cm 0xffffff8000b3e8b8 ccb 0xfffffe000fff0800 (noperiph:mps0:0:4294967295:0): SMID 51 Aborting command 0xffffff8000b3e8b8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 554 command timeout cm 0xffffff8000b285d0 ccb 0xfffffe000fff0800 (noperiph:mps0:0:4294967295:0): SMID 52 Aborting command 0xffffff8000b285d0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 308 command timeout cm 0xffffff8000b14aa0 ccb 0xfffffe000fff0800 (noperiph:mps0:0:4294967295:0): SMID 53 Aborting command 0xffffff8000b14aa0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 768 command timeout cm 0xffffff8000b39800 ccb 0xfffffe001806e800 (noperiph:mps0:0:4294967295:0): SMID 54 Aborting command 0xffffff8000b39800 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 378 command timeout cm 0xffffff8000b1a450 ccb 0xfffffe001806e800 (noperiph:mps0:0:4294967295:0): SMID 55 Aborting command 0xffffff8000b1a450 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 394 command timeout cm 0xffffff8000b1b8d0 ccb 0xfffffe07187b9800 (noperiph:mps0:0:4294967295:0): SMID 56 Aborting command 0xffffff8000b1b8d0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 793 command timeout cm 0xffffff8000b3b808 ccb 0xfffffe07187b9800 (noperiph:mps0:0:4294967295:0): SMID 57 Aborting command 0xffffff8000b3b808 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 307 command timeout cm 0xffffff8000b14958 ccb 0xfffffe0018030800 (noperiph:mps0:0:4294967295:0): SMID 58 Aborting command 0xffffff8000b14958 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 227 command timeout cm 0xffffff8000b0e2d8 ccb 0xfffffe0018030800 (noperiph:mps0:0:4294967295:0): SMID 59 Aborting command 0xffffff8000b0e2d8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 641 command timeout cm 0xffffff8000b2f548 ccb 0xfffffe01a7b63800 (noperiph:mps0:0:4294967295:0): SMID 60 Aborting command 0xffffff8000b2f548 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 690 command timeout cm 0xffffff8000b33410 ccb 0xfffffe01a7b63800 (noperiph:mps0:0:4294967295:0): SMID 61 Aborting command 0xffffff8000b33410 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 856 command timeout cm 0xffffff8000b408c0 ccb 0xfffffe01a7b63800 (noperiph:mps0:0:4294967295:0): SMID 62 Aborting command 0xffffff8000b408c0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 374 command timeout cm 0xffffff8000b19f30 ccb 0xfffffe000ffcd800 (noperiph:mps0:0:4294967295:0): SMID 63 Aborting command 0xffffff8000b19f30 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 490 command timeout cm 0xffffff8000b233d0 ccb 0xfffffe000ffcd800 (noperiph:mps0:0:4294967295:0): SMID 64 Aborting command 0xffffff8000b233d0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 750 command timeout cm 0xffffff8000b380f0 ccb 0xfffffe074c907000 (noperiph:mps0:0:4294967295:0): SMID 65 Aborting command 0xffffff8000b380f0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 338 command timeout cm 0xffffff8000b17110 ccb 0xfffffe074c907000 (noperiph:mps0:0:4294967295:0): SMID 66 Aborting command 0xffffff8000b17110 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 931 command timeout cm 0xffffff8000b468d8 ccb 0xfffffe074c907000 (noperiph:mps0:0:4294967295:0): SMID 67 Aborting command 0xffffff8000b468d8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 787 command timeout cm 0xffffff8000b3b058 ccb 0xfffffe074c907000 (noperiph:mps0:0:4294967295:0): SMID 68 Aborting command 0xffffff8000b3b058 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 137 command timeout cm 0xffffff8000b06f88 ccb 0xfffffe074c907000 (noperiph:mps0:0:4294967295:0): SMID 69 Aborting command 0xffffff8000b06f88 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 824 command timeout cm 0xffffff8000b3dfc0 ccb 0xfffffe000ff7a800 (noperiph:mps0:0:4294967295:0): SMID 70 Aborting command 0xffffff8000b3dfc0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 212 command timeout cm 0xffffff8000b0cfa0 ccb 0xfffffe000ff7a800 (noperiph:mps0:0:4294967295:0): SMID 71 Aborting command 0xffffff8000b0cfa0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 869 command timeout cm 0xffffff8000b41968 ccb 0xfffffe000ff7a800 (noperiph:mps0:0:4294967295:0): SMID 72 Aborting command 0xffffff8000b41968 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 795 command timeout cm 0xffffff8000b3ba98 ccb 0xfffffe000ff7a800 (noperiph:mps0:0:4294967295:0): SMID 73 Aborting command 0xffffff8000b3ba98 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 831 command timeout cm 0xffffff8000b3e8b8 ccb 0xfffffe000ff7a800 (noperiph:mps0:0:4294967295:0): SMID 74 Aborting command 0xffffff8000b3e8b8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 599 command timeout cm 0xffffff8000b2bf78 ccb 0xfffffe000ffc4000 (noperiph:mps0:0:4294967295:0): SMID 75 Aborting command 0xffffff8000b2bf78 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 584 command timeout cm 0xffffff8000b2ac40 ccb 0xfffffe000ffc4000 (noperiph:mps0:0:4294967295:0): SMID 76 Aborting command 0xffffff8000b2ac40 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 378 command timeout cm 0xffffff8000b1a450 ccb 0xfffffe000ff98800 (noperiph:mps0:0:4294967295:0): SMID 77 Aborting command 0xffffff8000b1a450 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 888 command timeout cm 0xffffff8000b431c0 ccb 0xfffffe000ff98800 (noperiph:mps0:0:4294967295:0): SMID 78 Aborting command 0xffffff8000b431c0 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 283 command timeout cm 0xffffff8000b12a98 ccb 0xfffffe0018078000 (noperiph:mps0:0:4294967295:0): SMID 79 Aborting command 0xffffff8000b12a98 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 451 command timeout cm 0xffffff8000b201d8 ccb 0xfffffe0018078000 (noperiph:mps0:0:4294967295:0): SMID 80 Aborting command 0xffffff8000b201d8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 913 command timeout cm 0xffffff8000b451c8 ccb 0xfffffe0018078000 (noperiph:mps0:0:4294967295:0): SMID 81 Aborting command 0xffffff8000b451c8 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 224 command timeout cm 0xffffff8000b0df00 ccb 0xfffffe0018078000 (noperiph:mps0:0:4294967295:0): SMID 82 Aborting command 0xffffff8000b0df00 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 213 command timeout cm 0xffffff8000b0d0e8 ccb 0xfffffe0018078000 (noperiph:mps0:0:4294967295:0): SMID 83 Aborting command 0xffffff8000b0d0e8 (da52:mps0:0:104:0): READ. CDB: 28 00 de 34 9f 90 00 00 e0 00 length 114688 SMID 221 terminated ioc 804b scsi 0 state c xfer 114688 (da52:mps0:0:104:0): READ. CDB: 28 00 de 34 a0 70 00 00 e0 00 length 114688 SMID 419 terminated ioc 804b scsi 0 state c xfer 0 (da52:mps0:0:104:0): READ. CDB: 28 00 de 34 9f 90 00 00 e0 00 (pass37:mps0:0:80:0): ATA COMMAND PASS THROUGH. CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 863 command timeout cm 0xffffff8000b411b8 ccb 0xfffffe000ffe2800 (noperiph:mps0:0:4294967295:0): SMID 84 Aborting command 0xffffff8000b411b8
Thank you!
Hardware:
RAIDZ2 (5x 9x3TB);
34GB RAM
