I got the following output from syslog. But as far as I see there are no information about any storage device and all the devices connected to my SAS card are still visible...
So what may be the problem?
(pass14:mps0:0:39:0): ATA COMMAND PASS THROUGH(16). CDB: 85 06 2c 00 da 00 00 00 00 00 4f 00 c2 00 b0 00 length 0 SMID 209 command timeout cm 0xfffffe0000ff2250 ccb 0xfffff805109ef800 (noperiph:mps0:0:4294967295:0): SMID 1 Aborting command 0xfffffe0000ff2250 mps0: Sending reset from mpssas_send_abort for target ID 39 mps0: Unfreezing devq for target ID 39 (pass15:mps0:0:43:0): ATA COMMAND PASS THROUGH(16). CDB: 85 06 2c 00 da 00 00 00 00 00 4f 00 c2 00 b0 00 length 0 SMID 213 command timeout cm 0xfffffe0000ff2790 ccb 0xfffff803efafc000 (noperiph:mps0:0:4294967295:0): SMID 2 Aborting command 0xfffffe0000ff2790 mps0: Sending reset from mpssas_send_abort for target ID 43 mps0: Unfreezing devq for target ID 43 (pass16:mps0:0:44:0): ATA COMMAND PASS THROUGH(16). CDB: 85 06 2c 00 da 00 00 00 00 00 4f 00 c2 00 b0 00 length 0 SMID 122 command timeout cm 0xfffffe0000feb020 ccb 0xfffff803efafc000 (noperiph:mps0:0:4294967295:0): SMID 3 Aborting command 0xfffffe0000feb020 mps0: Sending reset from mpssas_send_abort for target ID 44 mps0: Unfreezing devq for target ID 44 (pass17:mps0:0:45:0): ATA COMMAND PASS THROUGH(16). CDB: 85 06 2c 00 da 00 00 00 00 00 4f 00 c2 00 b0 00 length 0 SMID 1008 command timeout cm 0xfffffe0001033b00 ccb 0xfffff803efafc000 (noperiph:mps0:0:4294967295:0): SMID 4 Aborting command 0xfffffe0001033b00 mps0: Sending reset from mpssas_send_abort for target ID 45 mps0: Unfreezing devq for target ID 45
