CAM status: SCSI Status Error in dmesg
mosh
Today i experienced my first glitch of the freeNAS storage (FreeNAS-9.10.2-U4)
I noticed the following error in dmesg, and I want to ask your assistance on how to extract the most valuable information from it
such as:
Does that means that da0 disk experienced write failure, how can i test the disk (ssd)? should i consider replacing it?
(da0:mps0:0:0:0): WRITE(10). CDB: 2a 00 98 c0 74 b8 00 00 18 00 length 12288 SMID 634 command timeout cm 0xfffffe0001724020 ccb 0xfffff81fd8297000
from the following line i understand the LSI unit was reset or the bus reset, but how can I know which happened?
(da0:mps0:0:0:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
How can I check its condition?
(da0:mps0:0:0:0): SCSI status: Check Condition
Thanks for your comments
-Mosh
Full dmesg log:
	(noperiph:mps0:0:4294967295:0): SMID 1 Aborting command 0xfffffe0001724020
mps0: Sending reset from mpssas_send_abort for target ID 0
	(da0:mps0:0:0:0): WRITE(10). CDB: 2a 00 98 a1 e4 e8 00 00 50 00 length 40960 SMID 160 command timeout cm 0xfffffe00016fd200 ccb 0xfffff8137a6b7800
	(da0:mps0:0:0:0): READ(10). CDB: 28 00 7d 02 49 50 00 00 08 00 length 4096 SMID 239 terminated ioc 804b scsi 0 state c xfer 0
	(da0:mps0:0:0:0): ATA COMMAND PASS THROUGH(16). CDB: 85 0d 06 00 01 00 01 00 00 00 00 00 00 40 06 00 length 512 SMID 481 term(da0:mps0:0:0:0): READ(10). CDB: 28 00 7d 02 49 50 00 00 08 00
(da0:mps0:0:0:0): CAM status: CCB request completed with an error
	(da0:mps0:0:0:0): WRITE(10). CDB: 2a 00 98 a1 e4 e8 00 00 50 00 length 40960 SMID 160 terminated ioc 804b scsi 0 state c xfer(da0: 0
mps0:0:mps0: 0:Unfreezing devq for target ID 0
0): Retrying command
(da0:mps0:0:0:0): Retrying command
(da0:mps0:0:0:0): CAM status: Command timeout
(da0:mps0:0:0:0): CAM status: SCSI Status Error
(da0:mps0:0:0:0): Retrying command (per sense data)
(da0:mps0:0:0:0): READ(10). CDB: 28 00 a2 ef 93 b0 00 00 08 00
Chris Moore
In the GUI, is the disk listed as online or not?
Usually, seeing something like this indicates that the disk has failed, but it could be a wiring issue. As it says, check that the disk is present, healthy, online, etc. Find out things about the disk and let us know what you have found.
One of the moderators wrote this guide that might help:
https://forums.freenas.org/index.ph...leshooting-guide-basic-common-failures.41026/
