rockstar0215
- Dec 26, 2013
Hi everyone,
I've been hanging around the forum for a while without finishing my build. A while back I acquired an Super Micro X9 mother board and a chassis for my server. I never actually put the thing together. Now that the X10 series of MoBos are coming out, I think it's finally time to finish this old build or my gear will be severely outdated.
I am seeking some advice regarding some parts to verify that they're still good buys. The server will be primarily for movie storage. It may do some transcoding from time to time, but mostly it will be used to stream files to the local network that can natively support the file (no transcoding required).
Problem: I am not sure what BIOS firmware my MoBo has installed. This limits my processor and memory choice.
The Build
Supre Micro X9SCM-F
Either a G2020 (socket 1155 and ECC support) or an Intel Xeon 1220 (not v2 because I hear that that I would need to flash the MoBo with firmware to get the v2 working)
Memory: ??? Not a clue. Any advice? (this goes back to the processor problem; the new Bios which I am not sure I have installed does supports 1600 ECC RAM. Does this mean the 1220 v1 does not use 1600 RAM only the v2?) What does everyone recommend? Super Micro recommends Hynix or Samsung RAM, how about Crucial?
**NOTE** the G2020 only supports 1333 RAM; the 1220 supports 1333/1066; the 1220 v2 supports 1333/1600; the MoBo supports 1333 and 1600 RAM. 1333 is the common dominator here.
Power Supply: EVGA 650W Gold (WD Red 4TB x 5) Is this enough power? Is 550w enough?
The price between the G2020 and the Xeon is only $10 (new vs. old) so I think the choice is obvious here: Xeon. Anyone can chime in? I would prefer the E3-1220 v2 for the speed bump, but not knowing whether my MoBo is compatible is a headache I want to avoid. Am I wrong here?
Hard Drives and ZFS
Originally I planned to run 3 hard drives + 2 parity for double redundancy (RaidZ2). I also considered doing a 2 hard drive + 1 parity (RaidZ) and doing two pools. This way I can get into the game quicker without having purchased all 5 or 6 hard drives at once. Everyone always advises against only single parity because drives fail during rewriting. So I think RaidZ2 would be better? I can always add a second RaidZ2 pool if I want to expand.
The Build
Supre Micro X9SCM-F
Hard Drives and ZFS
