Mynorx
- Aug 26, 2014
I'm gonna go with members EXPERIENCE and thread recommendations. Can you guys help me out by letting me know of any quirks I may run into while using these components? I also ran into a little problem at the super micro website, the compatible memory listed on their site cannot be found on newegg. Can you guys recommend some good tested memory for this mobo? that can be found on newegg I'll also call them tomorrow morning and ask their tech support department. I wanna try to get all the components tomorrow so I have something fun to play with over the long weekend : P Thanks
BTW if I get to order my components early enough, I'll be able to will call them at new egg MAÑANA. If you guys haven't been, its a pretty sweet location, they have all kinds of cool floor demos set up.
I used this guide to build my components configuration
http://forums.freenas.org/index.php?threads/hardware-recommendations-read-this-first.23069/
1.Mobo. SUPERMICRO MBD-X10SLL-F-O uATX Server Motherboard LGA 1150 DDR3 1600
http://www.newegg.com/Product/Produ...ERMICRO_MBD-X10SL7-F-O-_-13-182-821-_-Product
2. CPU. Intel Core i3-4330 Haswell Dual-Core 3.5GHz LGA 1150 54W Desktop
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116945
3. Memory I cant find the memory they recommend for this board on new egg. do you guys know of any other ECC RAM I can use with it?
http://www.supermicro.com/support/r...B86C662FB2FD6&prid=0&type=0&ecc=0®=0&fbd=0
4. Flash Drive Kingston DataTraveler microDuo 16GB Micro USB OTG Flash Drive Model DTDUO/16GB
20% off promo code if any one is interested EMCPBHB83
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239886
5. PSU ENERMAX REVOLUTION X't ERX530AWT 530W ATX12V 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194111&ignorebbr=1
I have an old enermax I purchased in 2003~4 that's been in a bunch of systems, Its still running to this day. This one should be solid as well.
6. 4 of these Western Digital Red NAS Hard Drive WD30EFRX 3TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" NAS Hard Drive
$10 bucks off promo code if any one is interested SYFHD825
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236344
7. Case LIAN LI PC-Q25B Black Aluminum Mini-ITX Tower (looks cool)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112339
