Suggestion for harddrive combination
gpsguy
Active Member
I've been buying Crucial RAM for many and have never had a problem. A lot of Forum users, whether in the US or Internationally, use Crucial too.
Kingston has done some dodgy things in the past.
Can you elaborate? :) Why is it preferrable?
Stux
Agree with @gpsguy
Crucial is Micron. They make the stuff.
chbla
I've ordered the Crucial now, will be here on Monday.
If I create a mirror of 2x2TB, is it possible to add a full disk, then add a second empty one? Otherwise I need to make plans how to move all this data
Stux
Yes, make your mirror. Extend it with a stripe.
Later you add the new disk to the stripe with the command line, converting it to a mirror
Note: a stripe has no redundancy, and if that disk fails you lose your pool.
Amu W Ramappa
Stick with 9.10, also have a backup drive. ZFS RAIDz is not a reason to not have backups of ur datasets.
Sent from my Nexus 6P using Tapatalk
chbla
Stux
Looks like the right steps to me.
The tricky part is formatting the disk
chbla
on the first cmd I get:
$ gpart create -s gpt /dev/ada1
gpart: geom 'ada1': File exists
edit: got it, had to delete partitions and destroy first
