Been running freenas -> truenas for a long time, but still a bit of a novice (it's been very good to me and I haven't had to mess-around too much with it)...
Just received an alert of "Pool pool1 state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected." Sure enough, the pool (creatively named "pool1" ;) ) shows unhealthy...
Just about 1hr later I get the next alert: "Device: /dev/ada2, ATA error count increased from 0 to 5."
So that's the details I have...can anyone help me understand whether I should replace ata2 ASAP, or try some other troubleshooting?
Thanks very much,
AJ
zpool status -v pool1
pool: pool1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: scrub repaired 0B in 08:30:27 with 0 errors on Thu Sep 1 08:30:28 2022
NAME STATE READ WRITE CKSUM
pool1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/a577c0fe-ab6f-11e6-a104-10bf48b6ddea ONLINE 0 0 0
gptid/a67b47c3-ab6f-11e6-a104-10bf48b6ddea ONLINE 0 0 0
gptid/a77d0f33-ab6f-11e6-a104-10bf48b6ddea ONLINE 1 0 0
errors: No known data errors
smartctl -a /dev/ada2
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p11 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N4AJUXKZ
LU WWN Device Id: 5 0014ee 2630f6d04
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Sep 1 14:41:37 2022 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (39540) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 397) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 6
3 Spin_Up_Time 0x0027 183 180 021 Pre-fail Always - 5850
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 61
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 038 038 000 Old_age Always - 45932
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 61
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 43
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 589
194 Temperature_Celsius 0x0022 118 112 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 5
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 45931 hours (1913 days + 19 hours)
ER ST SC SN CL CH DH
40 51 80 58 f5 18 e6 Error: UNC 128 sectors at LBA = 0x0618f558 = 102298968
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 80 50 f5 18 e6 00 4d+05:34:28.543 READ DMA
c8 00 80 50 f5 18 e6 00 4d+05:34:25.147 READ DMA
c8 00 80 50 f5 18 e6 00 4d+05:34:21.750 READ DMA
c8 00 80 50 f5 18 e6 00 4d+05:34:18.343 READ DMA
c8 00 80 50 f5 18 e6 00 4d+05:34:14.973 READ DMA
Error 4 occurred at disk power-on lifetime: 45931 hours (1913 days + 19 hours)
Error 3 occurred at disk power-on lifetime: 45931 hours (1913 days + 19 hours)
c8 00 80 d0 f2 18 e6 00 4d+05:34:14.961 READ DMA
Error 2 occurred at disk power-on lifetime: 45931 hours (1913 days + 19 hours)
c8 00 80 50 f2 18 e6 00 4d+05:34:14.961 READ DMA
Error 1 occurred at disk power-on lifetime: 45931 hours (1913 days + 19 hours)
c8 00 80 d0 f1 18 e6 00 4d+05:34:14.961 READ DMA
# 1 Short offline Completed without error 00% 45823 -
# 2 Short offline Completed without error 00% 45655 -
# 3 Short offline Completed without error 00% 45487 -
# 4 Short offline Completed without error 00% 45320 -
# 5 Short offline Completed without error 00% 45152 -
# 6 Short offline Completed without error 00% 44984 -
# 7 Short offline Completed without error 00% 44816 -
# 8 Short offline Completed without error 00% 44648 -
# 9 Short offline Completed without error 00% 44480 -
#10 Short offline Completed without error 00% 44313 -
#11 Short offline Completed without error 00% 44145 -
#12 Short offline Completed without error 00% 43977 -
#13 Short offline Completed without error 00% 43809 -
#14 Short offline Completed without error 00% 43641 -
#15 Short offline Completed without error 00% 43474 -
#16 Short offline Completed without error 00% 43314 -
#17 Short offline Completed without error 00% 43138 -
#18 Short offline Completed without error 00% 42974 -
#19 Short offline Completed without error 00% 42802 -
#20 Short offline Completed without error 00% 42634 -
#21 Short offline Completed without error 00% 42467 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.So that's the details I have...can anyone help me understand whether I should replace ata2 ASAP, or try some other troubleshooting?
Thanks very much,
AJ
