I have two new 2TB MX500 SSDs in my TrueNas system and now twice received emails warning from one of them:
"* Device: /dev/ada1, 1 Currently unreadable (pending) sectors."
Oct 28 02:21:28 truenas 1 2020-10-28T02:21:28.927182+00:00 truenas.local smartd 1632 - - Device: /dev/ada1, 1 Currently unreadable (pending) sectors
Oct 30 17:21:28 truenas 1 2020-10-30T17:21:28.604987+00:00 truenas.local smartd 1632 - - Device: /dev/ada1, 1 Currently unreadable (pending) sectors
The odd thing is that the Current_Pending_Sector count is 0 if I check manually with smartctl:
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
Does anyone have an idea why this might be being mis-reported?
Thanks.
P.S. I will upgrade to the 12.2-RELEASE soon but don't expect that it would impact this issue.
root@truenas[~]# smartctl -a /dev/ada1
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-PRERELEASE amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Crucial/Micron BX/MX1/2/3/500, M5/600, 1100 SSDs
Device Model: CT2000MX500SSD1
Serial Number: 2029202920295D
LU WWN Device Id: 5 00a075 1e2b83b5d
Firmware Version: M3CR032
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Oct 30 19:20:35 2020 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 0) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 30) minutes.
Conveyance self-test routine
SCT capabilities: (0x0031) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 80
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 8
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 100 100 000 Old_age Always - 1
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 0
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 54
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 0
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 076 064 000 Old_age Always - 24 (Min/Max 0/36)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 0
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 1046292791
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 8700670
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 15530380
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 1
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 0 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
ER ST SC SN CL CH DH
00 ec 00 00 00 00 00
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ec 00 00 00 00 00 00 00 00:00:00.000 IDENTIFY DEVICE
c8 00 00 00 00 00 00 00 00:00:00.000 READ DMA
# 1 Short offline Completed without error 00% 80 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Thanks.
been run.
command.
power-saving mode.
ATA Error Count: 0
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
