SMART Error passed, only 3 errors though. Usable?
diskdiddler
See below - got 3 errors, kicked off SMART FULL and SMART SHORT - no further errors upon the full surface scan.
Would this disk be ok to use for relatively unimportant data? it seems to be passing the test.
SMART Error Log Version: 1
ATA Error Count: 3
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 3 occurred at disk power-on lifetime: 4308 hours (179 days + 12 hours)
ER ST SC SN CL CH DH
40 51 18 80 9e 83 01 Error: WP at LBA = 0x01839e80 = 25403008
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 00 68 b8 00 b7 40 00 1d+03:02:49.773 WRITE FPDMA QUEUED
61 00 60 b8 ff b6 40 00 1d+03:02:49.773 WRITE FPDMA QUEUED
61 00 58 b8 fe b6 40 00 1d+03:02:49.773 WRITE FPDMA QUEUED
61 00 50 b8 fd b6 40 00 1d+03:02:49.773 WRITE FPDMA QUEUED
61 00 48 b8 fc b6 40 00 1d+03:02:49.773 WRITE FPDMA QUEUED
Error 2 occurred at disk power-on lifetime: 4308 hours (179 days + 12 hours)
40 51 18 d0 e9 13 08 Error: WP at LBA = 0x0813e9d0 = 135522768
61 00 10 50 ae 9f 40 00 1d+02:59:02.182 WRITE FPDMA QUEUED
61 00 08 50 ad 9f 40 00 1d+02:59:02.182 WRITE FPDMA QUEUED
61 00 00 50 ac 9f 40 00 1d+02:59:02.182 WRITE FPDMA QUEUED
61 00 f8 50 ab 9f 40 00 1d+02:59:02.182 WRITE FPDMA QUEUED
61 00 f0 50 aa 9f 40 00 1d+02:59:02.182 WRITE FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 4308 hours (179 days + 12 hours)
40 51 28 50 7f 80 0e Error: WP at LBA = 0x0e807f50 = 243302224
61 00 08 90 a4 3e 40 00 1d+02:56:12.320 WRITE FPDMA QUEUED
61 00 e8 90 a3 3e 40 00 1d+02:56:12.318 WRITE FPDMA QUEUED
61 00 e0 90 a2 3e 40 00 1d+02:56:12.317 WRITE FPDMA QUEUED
61 00 d8 90 a1 3e 40 00 1d+02:56:12.314 WRITE FPDMA QUEUED
61 00 d0 90 a0 3e 40 00 1d+02:56:12.313 WRITE FPDMA QUEUED
# 1 Short offline Completed without error 00% 4318 -
# 2 Extended offline Completed without error 00% 4311 -
