Subcarpeta de carpeta compartida
Hello, my name is Albert and I am filing a problem. I recently installed TrueNAS on my system but when sharing the folders from TrueNAS, from Windows the subfolders and files of it do not appear. Example:
In TrueNAS create a folder called "Cideter Backup" and it has many subfolders. But in Windows I only see the root folder (as shown in the images).
Please, could someone help me to solve this problem or explain to me how this system works. From already thank you very much.
The characteristics of my RAID are as follows:
  • Motherboard make and model: Gigabyte B560M DS3H V2
  • CPU make and model: Intel(R) Core(TM) i3-10105 CPU @ 3.70GHz
  • RAM quantity: 8GB
  • Hard drives, configuration: HD Blue 1TB (x2) mirror
If you do not see anything, it is a question of permissions, check the permissions, you must add the user and or the group in the ACL lists, give them read, execute or full control permission and recursively apply the permissions
Hola, mi nombre es Albert y estoy presentando un problema. Hace poco he instalado TrueNAS en mi sistema pero a la hora de compartir las carpetas desde TrueNAS, desde Windows no aparecen las subcarpetas ni los archivos de esta misma. Ejemplo:
En TrueNAS cree una carpeta llamada "Cideter Backup" y tiene muchas subcarpetas. Pero en Windows solo me aparece la carpeta raíz (como se muestran en las imágenes).
Por favor, alguien podría ayudarme a solucionar este problema o explicarme como funciona este sistema. Desde ya muchas gracias.
Las características de mi RAID son las siguientes:
  • RAM quantity: 8GB
Si no vez nada es cuestion de permisos, checa los permisos, debes de agregar al usuario y o al grupo en las listas ACL, darles permiso de lectura ejecucion o control total y aplicar recursivamente los permisos
jgreco
Resident Grinch
Greetings -
Welcome to these forums.
Please note that the main forums are English language, and you are expected to post in English here. We have a section for International discussion that includes a Spanish section, and you may post in Spanish there. Supporting multiple languages in the main forums is untenable. If you do not speak English natively, please know that we're fine with machine-translated messages from services such as Google Translate. These don't always work well, but we will still definitely try to help you!
Your post has been translated with Google Translate.
Saludos -
Bienvenido a estos foros.
Tenga en cuenta que los foros principales están en inglés y se espera que publique en inglés aquí. Tenemos una sección para discusión internacional que incluye una sección en español, y puedes publicar en español allí. La compatibilidad con varios idiomas en los foros principales es insostenible. Si no habla inglés de forma nativa, sepa que estamos de acuerdo con los mensajes traducidos automáticamente de servicios como Google Translate. Estos no siempre funcionan bien, ¡pero definitivamente intentaremos ayudarte!
Tu publicación ha sido traducida con Google Translate.
