su to root possible without being in wheel
lubos
my build is "FreeNAS-8.0.3-RELEASE-p1-x86 (9591)". Any user I create is able to su to root without being added to wheel group. Is this anyhow on purpose? Or is it corrected in later versions?
Thanks in advance,
Lubos
peterh
Quoting the manpage of "su" :
PAM is used to set the policy su(1) will use. In particular, by default
only users in the ``wheel'' group can switch to UID 0 (``root''). This
group requirement may be changed by modifying the ``pam_group'' section
of /etc/pam.d/su. See pam_group(8) for details on how to modify this
setting.
so, pam seems reconfigured from stock freebsd.
i do not however see the difference ..
lubos
There is a line "auth requisite pam_group.so no_warn group=wheel root_only fail_safe", which on FreeBSD ends with "ruser" (only difference). I tried to append this word on FreeNAS, but it's removed after reboot. Deleting "ruser" on FreeBSD, however, doesn't matter, PAM outputs "assuming ruser" and forbids su to root.
Well, I guess it's on purpose. CLI is also accessible without password, so FreeNAS needs to be running on a secure machine at any rate.
