Stumped with Nextcloud on FN11.3u5 AND TNC12RC1
Tim1962
First Q. Am I alone in being stumped trying to install latest NC 20 plugin, both in 11.3 and also 12RC1
For 11.3 I can't get past the untrusted domain, despite all the editing of config.php I can think of
For 12RC1 I get the log in screen, and try to use ncadmin/password combo and then it fails to connect. I've tried accessing via http and https throughout variously
Tried via DHCP and NAT without significant change
Second Q. and its not a bug, is there any easy solution that's not out there already, (tried 50-100 google and forum results!!!)
PS Various advise suggests adding the plugin IP address to config.php (in my case FN is 192.168.0.110. NC is on 192.168.0.227) but when I add the. NC IP I can't connect at all. Restart plugin each time obviously
PPS Variously seen 192.168.0.* should work but can't connect when I tried that.
exeter_acres
sounds similar to what is happening to me... when I try to connect, I get the Untrusted Domains screen... when I edit the config.php file and add the line for the NC server IP address.. can't connect at all...
remove the line, it connects...but still just the untrusted domains screen...
can't get past it
Tim1962
OK, sounds like needs a bug report if we are not alone... Anyone else?
What FN release are you on?
Tim1962
Looks like its already reported, or similar
NAS-107926
exeter_acres
Hmm...this may be it... tried typing just http://192.168.1.26 (Nextcloud server) in Chrome...still no go...
but direct typed it into MS Edge... and it at least brought up the log on screen... typed credentials and yes... it then went to the Refused to Connect page and the address had in fact changed to Https.......
exeter_acres
Can't see how to add a comment to that Bug report just to mention that I am having that exact issue.....
Tim1962
See similar thread but just to confirm...
I added the ip address of my jail as line 2 trusted domain.
0 => 'localhost',
1 => '192.168.0.110',
2 => '192.168.0.227',
then lower pasted this in
'overwriteprotocol' => 'http',
Bingo! You may wish to try it too. Now, YMMV about http/https but I am happy with my firewall and family access.
But maybe changing
2 => '192.168.0.227', to 2 => '192.168.0.227:443', may also do it, but just received to have found a fix
