Hello all!
I've successfully assembled a few FreeNAS systems using HP DL360 G6 servers, USB flash drives for booting, HP D2600 drive arrays, LSI 9200-8e controllers (flashed to v20 IT firmware), and bunches of Seagate 4TB 6Gbps SAS drives (ST4000NM0023). Everything worked great. With that done, I've moved onto a new project.
The server in question is a HP StorageWorks P4500 G2 (basically a DL180 G6 bundled with SAN software). I installed a Dell H310, cross-flashed with 9200-8e firmware (as here); and added a small SATA SSD to one of the on-board SATA ports for booting (easier than wiring up an internal USB port). FreeNAS installed and booted fine.
The trouble came when I installed the drives - same model as mentioned above. Each displayed "300.0000MB/s transfers" on the console as I pushed them into place. This leads me to believe that I'm only running at 3Gbps.
The drives are capable of 6Gbps. The controller *should* be capable of 6Gbps (unless there's some hitch related to cross-flashing that I don't know about). A bit of quick Googling suggests the server's built-in expander is capable of 6Gbps.
So, what am I missing here?
