Streaming from NTFS drive (read-only)
HeyRicardo
I'd like to ask whether it is feasible to mount an NTFS drive and share its content for streaming purposes.
Since we may transfer files from NTFS to NAS storage drives, I hope this is not different than reading a file and trasmit it via a network protocol like CIFS.
SweetAndLow
Sweet'NASty
You well have performance issues because you probably want to use USB. In also not sure if it can be mounted in a jail. But you should try and report back.
Robert Trevellyan
Pony Wrangler
L
L
Guest
I like the idea of running your application in a jail. You won't be sending over the network to the device sending the stream from ntfs, it will actually be on a zpool in freenas.
