bikefright
- Jul 4, 2016
Hello folks,
Running 9.10.2-U3 on an AMD Phenom platform with 16GB RAM for home use.
Got a real strange one (for me anyway). I recently had cause to delete the one and only headphones jail that I have had running for at least a couple of years. I had tried to make a change to the search providers section unsuccessfully and began to experience strange behaviour. Specifically, I was removing the three or so custom newznab providers I had previously configured in favour of a single all-singing all-dancing newly set-up nzbhydra instance (plugin jail) on my freenas. Settings were not saving correctly and the various check boxes to "enable/disable" each provider, the content of the host/api boxes and the "remove" buttons were all exhibiting very odd behaviour (shifting order, not deleting upon hitting remove etc.)
I took some screen captures of the original settings tabs for reference, made a note of the storage mounted to the jail in freenas and disabled the plugin in the GUI.
I set about knife and forking the config.ini in /var/db/headphones, but I was unable to fix the problem. For reference this original long-standing jail was assigned the ip address 192.168.1.112 and mac 02:ff:b0:00:07:0b and was called headphones_1
I created a second headphones jail (headphones_2) which was assigned the ip address 192.168.1.115 and mac 02:ff:b0:00:0a:0b. This worked perfectly from the get-go and the weird behaviour in the settings section had disappeared - I was faced with a blank canvas with none of the user entered fields populated and no artefacts; so I set about filling in the blanks from my screen captures and everything was great.............until I had the bright idea to change the IP address of the jail back to the original 192.168.1.112 - at which point, the search providers settings page exhibited the same behaviour as before and was overwritten by what I am deeming an artefact from the original corrupt plugin jail. It was again unfixable.
At this point, I threw my toys out of my pram, took a backup of my headphones.db file, removed the storage from the jails and deleted both plugins entirely!
I also rebooted the freenas here.
I installed the headphones plugin again which became headphones_1 and I assigned this plugin jail the Ip address 192.168.1.240. I browsed to the settings page and as expected - a blank canvas with no artefacts. I made no changes, i.e. I left the settings untouched from install with none of the blank fields populated. I disabled the plugin, shutdown the jail, assigned it the ip address 192.168.1.112 and restarted the jail and plugin.......guess what? Even though I had not mad ANY changes to the settings tabs, all sorts of stuff was suddenly there as if by magic.....my sabnzbd server with it's custom non-standard port and API key were there.....and on the search providers tab, an old newznab provider I had originally configured not he original jail nzb.cat and its API key were populated. Again, I was unable to make the changes to the newznab providers section with any degree of success :-(
Something is being cached somewhere (and it's not my browser - cleared everything from both browsers I use and I've tried iPad, iMac, MacBook, Windoze desktop, even firefox from a raspberry pi running max2play - all with the same results)
For now I have a working solution: I will stick to a fresh build with the ip address 192.168.1.115, but my OCD is telling me to get this fixed and restore zen to my freenas.
Help! What am I doing wrong? What am I missing? It has to be something simple surely!
ATB,
Rowland.
ATB,
Rowland.
