Strange folders and plex plugin error?
nearbyatom
I created my datasets called Server and Plugin Jails (see pic scrn4)
I go to file explorer instead I see homes and root (see pic scrn5)
I go to Plugins and I found the PlexMedia Server Plugin. I select and hit install instead I get an error of some sort (see pic 6)
Where did I go wrong?
SweetAndLow
Sweet'NASty
Hardware specs and freenas version? Did you try reading the manual or noob guide? I would start by using the default jail dataset so there is no strange names with spaces.
Chris Moore
The resources section of the Forum has guides that tell you how to set up most things.
