Storage, data sets and hidden volumes
pete.magnusson
As you might understand i am new to FreeNAS (something i am kicking myself for more and more after 2 days of usage :)
But i understand that there is something i dont understand.
Creating datasets seams like what i want to do, but i have mananged to create some "hidden" parts on the storage device aswell.
Like in this image, the "folder" movies cant be created as a data set as i have already created it.
I named something movies because i "thought" it would create a folder.
Dose anyone know how i can correct this and create a data set names "movies"?
Sorry if this is a totaly stupid questions, tried googling but didnt give me much :(
Thanks
But i understand that there is something i don't understand.
Quite a lot, no doubt, but don't let that bother you--there's at least one "something" for all of us. Unfortunately, the image you tried to attach didn't come through, so it's hard to see what you're talking about. You can just paste images into your post (at least if you're using Firefox), or use the Upload a File button to upload them.
pete.magnusson
Wops! my bad! Thanks for the notice!
This is the image
Cheers
So you've apparently created a subdirectory at /mnt/storage/content/movies. Directories don't show on the Storage page, only pools and datasets--that's why you aren't seeing it on that page. In the past, FreeNAS would let you create a dataset over the top of an existing directory, which resulted in a good bit of confusion (when that happens, any data that was already in the directory gets hidden). Now, FreeNAS (usually) prevents you from doing that. So, you have a couple of options:
  • Don't create a dataset at all, and just use the existing directory.
  • If you want a dataset for your movies, rename the directory (to something like movies2), create the dataset, then move everything from movies2/ to movies/.
pete.magnusson
Thanks @danb35 ,
Just one last question if you dont mind, can i rename the sub-directory?
Of course, but not through the FreeNAS web GUI. It'd be easy to do at the CLI ( mv movies movies2), or you might be able to do it through a networked computer's file browser, depending on how your shares are set up.
pete.magnusson
Awesome! Thanks!
