Keven
- Aug 10, 2016
Hi everyone
I’m new to the community. I’m planning a freenas build.
http://ca.pcpartpicker.com/list/fdGwhq
I’m planning to run RAIDZ1 to have some kind of efficiency at the beginning. My plan to be able to grow my storage size and efficiency is to eventually add a backup of my main pool. My backup would not be raid or mirror in order to be easy to add HDD to the backup pool as my storage needs grow. When my main pool is full, I plan to backup this pool to my backup and then I will buy a 5th HDD to the main pool and create a new vdev with all 5 HDD in RAID Z1. After that I would copy back all my data from my backup to my new and more efficient main pool.
If you looked at my build maybe you had notice that my motherboard have only 6 sata port and I will be using 4 at the beginning so for the backup I will only have 2 left. So, is it possible to split the backup in 3 or 4 backup pool, so I only need 1 hard drive connect to the machine at a time to make a partial backup? for example: 1 drive for my movie, 1 drive for my picture… with this method is it possible to also keep the snapshot I plan to make:
1 every day that last 4 weeks
1 every 4 week that last 25 years (like a life time snapshot)
I’m honest to myself and don’t expect my backup system to work with the snapshot, but it would be great.
My must is:
-I can upgrade my main pool one drive at a time while keeping RAIDZ1 redundancy and efficiency.
-keep my archival snapshot
Ps: my backup drive that I will buy eventually will not be online 24/7, I plan to only use them maybe once every 6 month so I expect them to be in top shape when I need them to work for a full backup
If my first plan of connecting 1 backup drive at a time have no way to work, I thought that a barebones PCI-e Sata adapter maybe the solution if nothing else work so I can connect them all at the same time.
My must is:
