Storage and Shares are gone
Sergey211
Been using running my Freenas Box for 2 years, and now its not working
it loads ok, and drives seems to be ok.
I can only see system information (below) when Login to GUI
other tabs not showing up :(
Connected the monitor and have menu, one of the menu items is to load default settings
will i loose data if i go default settings? Data is important for me!
I have 4x 2TB drives, ZFS, no Raid, in HP Microserver case, Freenas loads from 8GB usb drive.
System information:
Hostname FreeNAS BOX.local
FreeNAS Build FreeNAS-8.0.4-RELEASE-p3-x64 (11703)
Platform AMD Athlon(tm) II Neo N36L Dual-Core Processor
Memory 8049MB
System Time Sat Apr 12 15:13:36 2014
Uptime 3:13PM up 20 mins, 0 users
Load Average 0.00, 0.02, 0.06
OS Version FreeBSD 8.2-RELEASE-p9
DrKK
FreeNAS Generalissimo
Can you access the command line interface? What does "zpool status" say?
and what does "zpool import" say?
Please put the output of both in pastebin as the formatting of the text is crucial.
