metaslab_load/spa_load errors at startup on all my pools
seldo
I noticed I am getting a set of metaslab_load message + other related to it.
I found a couple of things related to these messages, but they are always associated with failures or error messages.
For two drives, I haven't done anything beyond creating empty pools. For the last one, it's picked up by the OS and I didn't manage it after creating the pool.
All drives are new, all from different brands.
I have three drives for which I created pools through the GUI: 1 SSD that I currently use for logs + swap (LOG_SWAP_POOL) and 2 8TB (1 WD, 1ST) that I want to mirror in a separate pool (ARCHIVE_POOL).
To see if the issue was related to the pool, I did a version with 3 pools (LOG_SWAP_POOL (unchanged), POOL_0, POOL_D1)
I got the issue on both configurations (the LOG_SWAP_POOL is the same on each run).
I tried to reproduce the issue in a VM with two files acting as drives and I cannot see the errors, which makes me wonder (and worry...).
I will try tomorrow with the current drives on SATA on my VM (so I can check if that's the drives or the hardware surrounding it).
Any idea? And should I worry?
I will follow up tomorrow with my actual drives on SATA in a VM.
Log for LOG_SWAP_POOL + ARCHIVE_POOL
Mar 28 01:05:20 bob Beginning pools import
Mar 28 01:05:20 bob Importing LOG_SWAP_POOL
Mar 28 01:05:20 bob Importing ARCHIVE_POOL
Mar 28 01:05:20 bob mmp.c:241:mmp_thread_start(): MMP thread started pool 'LOG_SWAP_POOL' gethrtime 37403720605
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 12, smp_length 4392, unflushed_allocs 0, unflushed_frees 4096, freed 0, defer 0 + 0, unloaded time 37403 ms, loading_time 0 ms, ms_max_size 536870912, max si
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 14, smp_length 2904, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37404 ms, loading_time 0 ms, ms_max_size 536870912, max size
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 16, smp_length 3096, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37404 ms, loading_time 0 ms, ms_max_size 536870912, max size
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 20, smp_length 2056, unflushed_allocs 0, unflushed_frees 12288, freed 0, defer 0 + 0, unloaded time 37404 ms, loading_time 0 ms, ms_max_size 536870912, max s
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 21, smp_length 1632, unflushed_allocs 0, unflushed_frees 12288, freed 0, defer 0 + 0, unloaded time 37405 ms, loading_time 0 ms, ms_max_size 536870912, max s
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 36, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37405 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 37, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37405 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 38, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37406 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1325, spa LOG_SWAP_POOL, vdev_id 0, ms_id 39, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37406 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=LOG_SWAP_POOL async request task=1
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=LOG_SWAP_POOL async request task=2048
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load(LOG_SWAP_POOL, config trusted): LOADED
Mar 28 01:05:20 bob spa_history.c:309:spa_history_log_sync(): txg 1326 open pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1326, spa LOG_SWAP_POOL, vdev_id 0, ms_id 40, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1326, spa LOG_SWAP_POOL, vdev_id 0, ms_id 41, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1326, spa LOG_SWAP_POOL, vdev_id 0, ms_id 42, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1326, spa LOG_SWAP_POOL, vdev_id 0, ms_id 43, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1326, spa LOG_SWAP_POOL, vdev_id 0, ms_id 44, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1327, spa LOG_SWAP_POOL, vdev_id 0, ms_id 45, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1327, spa LOG_SWAP_POOL, vdev_id 0, ms_id 46, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1327, spa LOG_SWAP_POOL, vdev_id 0, ms_id 47, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 1327, spa LOG_SWAP_POOL, vdev_id 0, ms_id 48, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37434 ms, loading_time 0 ms, ms_max_size 536870912, max size err
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=LOG_SWAP_POOL async request task=32
Mar 28 01:05:20 bob spa_history.c:309:spa_history_log_sync(): txg 1328 import pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 01:05:20 bob spa.c:6138:spa_tryimport(): spa_tryimport: importing ARCHIVE_POOL
Mar 28 01:05:20 bob spa.c:6143:spa_tryimport(): spa_tryimport: using cachefile '/data/zfs/zpool.cache.saved'
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): LOADING
Mar 28 01:05:20 bob vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/d58b9551-8f58-11eb-80ce-00fd45fc0de0': best uberblock found for spa $import. txg 8
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load($import, config untrusted): using uberblock with txg=8
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=$import async request task=2048
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): LOADED
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): UNLOADING
Mar 28 01:05:20 bob spa.c:5990:spa_import(): spa_import: importing ARCHIVE_POOL
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load(ARCHIVE_POOL, config trusted): LOADING
Mar 28 01:05:20 bob vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/d58b9551-8f58-11eb-80ce-00fd45fc0de0': best uberblock found for spa ARCHIVE_POOL. txg 8
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load(ARCHIVE_POOL, config untrusted): using uberblock with txg=8
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load(ARCHIVE_POOL, config trusted): read 4 log space maps (4 total blocks - blksz = 131072 bytes) in 0 ms
Mar 28 01:05:20 bob mmp.c:241:mmp_thread_start(): MMP thread started pool 'ARCHIVE_POOL' gethrtime 38396908783
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=ARCHIVE_POOL async request task=1
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=ARCHIVE_POOL async request task=2048
Mar 28 01:05:20 bob spa_misc.c:411:spa_load_note(): spa_load(ARCHIVE_POOL, config trusted): LOADED
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 9, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size error
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 10, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 11, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 12, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 13, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 14, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 15, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 16, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 17, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38397 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob spa_history.c:309:spa_history_log_sync(): txg 10 open pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 18, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38583 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 19, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38583 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 20, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38583 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 21, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38583 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 22, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38584 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 23, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38584 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 24, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38584 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa ARCHIVE_POOL, vdev_id 0, ms_id 25, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38584 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa ARCHIVE_POOL, vdev_id 0, ms_id 26, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38584 ms, loading_time 0 ms, ms_max_size 17179869184, max size erro
Mar 28 01:05:20 bob spa.c:8187:spa_async_request(): spa=ARCHIVE_POOL async request task=32
Mar 28 01:05:20 bob spa_history.c:309:spa_history_log_sync(): txg 12 import pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 01:05:20 bob Pools import completed
seldo
Logs made me go over the max character per post o_O
LOG_SWAP_POOL + POOL_0 + POOL_D1
Mar 28 00:21:49 bob Beginning pools import
Mar 28 00:21:49 bob Importing LOG_SWAP_POOL
Mar 28 00:21:49 bob Importing POOL_0
Mar 28 00:21:49 bob mmp.c:241:mmp_thread_start(): MMP thread started pool 'LOG_SWAP_POOL' gethrtime 37466305750
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 27, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 28, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 29, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 30, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 31, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 32, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 33, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37466 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 34, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37467 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 834, spa LOG_SWAP_POOL, vdev_id 0, ms_id 35, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37467 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=LOG_SWAP_POOL async request task=1
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=LOG_SWAP_POOL async request task=2048
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(LOG_SWAP_POOL, config trusted): LOADED
Mar 28 00:21:49 bob spa_history.c:309:spa_history_log_sync(): txg 835 open pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 835, spa LOG_SWAP_POOL, vdev_id 0, ms_id 36, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 835, spa LOG_SWAP_POOL, vdev_id 0, ms_id 37, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 835, spa LOG_SWAP_POOL, vdev_id 0, ms_id 38, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 835, spa LOG_SWAP_POOL, vdev_id 0, ms_id 39, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 835, spa LOG_SWAP_POOL, vdev_id 0, ms_id 40, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 836, spa LOG_SWAP_POOL, vdev_id 0, ms_id 41, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 836, spa LOG_SWAP_POOL, vdev_id 0, ms_id 42, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 836, spa LOG_SWAP_POOL, vdev_id 0, ms_id 43, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 836, spa LOG_SWAP_POOL, vdev_id 0, ms_id 44, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 37494 ms, loading_time 0 ms, ms_max_size 536870912, max size erro
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=LOG_SWAP_POOL async request task=32
Mar 28 00:21:49 bob spa_history.c:309:spa_history_log_sync(): txg 837 import pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 00:21:49 bob spa.c:6138:spa_tryimport(): spa_tryimport: importing POOL_0
Mar 28 00:21:49 bob spa.c:6143:spa_tryimport(): spa_tryimport: using cachefile '/data/zfs/zpool.cache.saved'
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): LOADING
Mar 28 00:21:49 bob vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/89a74a9a-8f52-11eb-92cb-00fd45fc0de0': best uberblock found for spa $import. txg 8
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load($import, config untrusted): using uberblock with txg=8
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=$import async request task=2048
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): LOADED
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load($import, config trusted): UNLOADING
Mar 28 00:21:49 bob spa.c:6138:spa_tryimport(): spa_tryimport: importing POOL_D1
Mar 28 00:21:49 bob vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/9547f89a-8f52-11eb-92cb-00fd45fc0de0': best uberblock found for spa $import. txg 8
Mar 28 00:21:49 bob spa.c:5990:spa_import(): spa_import: importing POOL_0
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_0, config trusted): LOADING
Mar 28 00:21:49 bob vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/89a74a9a-8f52-11eb-92cb-00fd45fc0de0': best uberblock found for spa POOL_0. txg 8
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_0, config untrusted): using uberblock with txg=8
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_0, config trusted): read 4 log space maps (4 total blocks - blksz = 131072 bytes) in 25 ms
Mar 28 00:21:49 bob mmp.c:241:mmp_thread_start(): MMP thread started pool 'POOL_0' gethrtime 38493785876
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=POOL_0 async request task=1
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=POOL_0 async request task=2048
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_0, config trusted): LOADED
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 9, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 17179
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 10, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 11, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 12, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 13, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 14, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 15, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 16, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 17, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38494 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob spa_history.c:309:spa_history_log_sync(): txg 10 open pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 18, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 19, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 20, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_0, vdev_id 0, ms_id 21, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_0, vdev_id 0, ms_id 22, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_0, vdev_id 0, ms_id 23, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_0, vdev_id 0, ms_id 24, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_0, vdev_id 0, ms_id 25, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_0, vdev_id 0, ms_id 26, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 38683 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=POOL_0 async request task=32
Mar 28 00:21:49 bob spa_history.c:309:spa_history_log_sync(): txg 12 import pool version 5000; software version unknown; uts  12.2-RELEASE-p3 1202000 amd64
Mar 28 00:21:49 bob Importing POOL_D1
Mar 28 00:21:49 bob spa.c:5990:spa_import(): spa_import: importing POOL_D1
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_D1, config trusted): LOADING
Mar 28 00:21:49 bob vdev.c:129:vdev_dbgmsg(): disk vdev '/dev/gptid/9547f89a-8f52-11eb-92cb-00fd45fc0de0': best uberblock found for spa POOL_D1. txg 8
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_D1, config untrusted): using uberblock with txg=8
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_D1, config trusted): read 4 log space maps (4 total blocks - blksz = 131072 bytes) in 23 ms
Mar 28 00:21:49 bob mmp.c:241:mmp_thread_start(): MMP thread started pool 'POOL_D1' gethrtime 39801850585
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=POOL_D1 async request task=2048
Mar 28 00:21:49 bob spa_misc.c:411:spa_load_note(): spa_load(POOL_D1, config trusted): LOADED
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 9, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 1717
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 10, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 11, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 12, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 13, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 14, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 15, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 16, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 17, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39802 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=POOL_D1 async request task=1
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 18, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 19, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 20, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 10, spa POOL_D1, vdev_id 0, ms_id 21, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_D1, vdev_id 0, ms_id 22, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_D1, vdev_id 0, ms_id 23, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_D1, vdev_id 0, ms_id 24, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_D1, vdev_id 0, ms_id 25, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 11, spa POOL_D1, vdev_id 0, ms_id 26, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 39845 ms, loading_time 0 ms, ms_max_size 17179869184, max size error 171
Mar 28 00:21:49 bob spa.c:8187:spa_async_request(): spa=POOL_D1 async request task=32
Mar 28 00:21:49 bob Pools import completed
seldo
My boot-pool SSD is on an SSD, connected to USB through a USB<>SATA adapter.
All other drives are on SATA.
- the 2x8TB are through the pre-cabled SATA, so I just put them in the bay and that's it,
- the LOG_SWAP_POOL SSD in on a SATA port that I cabled myself.
All these drives are new.
I noticed that my boot-pool appeared in the log earlier this evening, in a configuration that doesn't exist at the moment (boot SSD + 2x8TB only) -- the LOG_SWAP_POOL SSD wasn't plugged in at that time.
seldo
Some more news this morning.
I am running TrueNAS 12.0 U2.1 (same as in my server hardware) in VirtualBox from macOS:
- I have attached through SATA (directly on the motherboard) the 2x 8TB drives.
- they don't have swap
- I have two virtual drives of 2 GB to create a pool that is unrelated to physical devices (the files are on a SSD)
- they are used only for swap
Here's how it looks for TrueNAS:
root@truenas[~]# gpart show
=>      40  33554352  ada0  GPT  (16G)
        40      1024     1  freebsd-boot  (512K)
      1064  33521664     2  freebsd-zfs  (16G)
  33522728     31664        - free -  (15M)
=>     40  8388528  ada1  GPT  (4.0G)
       40       88        - free -  (44K)
      128  4194304     1  freebsd-swap  (2.0G)
  4194432  4194136     2  freebsd-zfs  (2.0G)
=>     40  8388528  ada2  GPT  (4.0G)
=>         40  15628053088  ada3  GPT  (7.3T)
          128  15628053000     1  freebsd-zfs  (7.3T)
=>         40  15628053088  ada4  GPT  (7.3T)
In one boot, I created a TEST_POOL with the virtual drives.
In another booth, I created a ARCHIVE_POOL_PA with the 2x 8TB drives.
root@truenas[~]# zpool status
  pool: ARCHIVE_POOL_VM
 state: ONLINE
    ARCHIVE_POOL_VM                                 ONLINE       0     0     0
      mirror-0                                      ONLINE       0     0     0
        gptid/82e35529-8fb8-11eb-af3f-0800279e1322  ONLINE       0     0     0
        gptid/82fad297-8fb8-11eb-af3f-0800279e1322  ONLINE       0     0     0
errors: No known data errors
  pool: TEST_POOL
 state: ONLINE
    TEST_POOL                                       ONLINE       0     0     0
        gptid/e1b2ec7c-8f5b-11eb-8707-0800279e1322  ONLINE       0     0     0
        gptid/e1bba5bb-8f5b-11eb-8707-0800279e1322  ONLINE       0     0     0
  pool: boot-pool
 state: ONLINE
      ada0p2    ONLINE       0     0     0
On the next reboot, I have the following in my logs:
root@truenas[~]# grep _impl /var/log/console.log
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 10, smp_length 240, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19289 ms, loading_time 0 ms, ms_max_size 134217728, max size error
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 11, smp_length 280, unflushed_allocs 0, unflushed_frees 4096, freed 0, defer 0 + 0, unloaded time 19289 ms, loading_time 0 ms, ms_max_size 134217728, max size err
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 12, smp_length 296, unflushed_allocs 0, unflushed_frees 4096, freed 0, defer 0 + 0, unloaded time 19290 ms, loading_time 0 ms, ms_max_size 134217728, max size err
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 13, smp_length 384, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19290 ms, loading_time 0 ms, ms_max_size 134217728, max size error
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 14, smp_length 352, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19290 ms, loading_time 0 ms, ms_max_size 134217728, max size error
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 0, smp_length 1256, unflushed_allocs 815104, unflushed_frees 815104, freed 0, defer 0 + 0, unloaded time 19291 ms, loading_time 0 ms, ms_max_size 130957312, max s
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 176, spa TEST_POOL, vdev_id 0, ms_id 1, smp_length 1120, unflushed_allocs 372736, unflushed_frees 376832, freed 0, defer 0 + 0, unloaded time 19291 ms, loading_time 0 ms, ms_max_size 132804608, max s
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 177, spa TEST_POOL, vdev_id 0, ms_id 2, smp_length 1680, unflushed_allocs 688128, unflushed_frees 761856, freed 0, defer 32768 + 0, unloaded time 19297 ms, loading_time 0 ms, ms_max_size 131153920, m
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 177, spa TEST_POOL, vdev_id 0, ms_id 3, smp_length 912, unflushed_allocs 360448, unflushed_frees 393216, freed 0, defer 32768 + 0, unloaded time 19298 ms, loading_time 0 ms, ms_max_size 132186112, ma
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 177, spa TEST_POOL, vdev_id 0, ms_id 4, smp_length 1176, unflushed_allocs 790528, unflushed_frees 770048, freed 0, defer 8192 + 4096, unloaded time 19308 ms, loading_time 0 ms, ms_max_size 131461120,
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 178, spa TEST_POOL, vdev_id 0, ms_id 5, smp_length 1120, unflushed_allocs 311296, unflushed_frees 335872, freed 0, defer 8192 + 4096, unloaded time 19308 ms, loading_time 0 ms, ms_max_size 132706304,
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 178, spa TEST_POOL, vdev_id 0, ms_id 6, smp_length 2048, unflushed_allocs 0, unflushed_frees 4096, freed 0, defer 0 + 4096, unloaded time 19308 ms, loading_time 0 ms, ms_max_size 113397760, max size
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 178, spa TEST_POOL, vdev_id 0, ms_id 7, smp_length 1296, unflushed_allocs 0, unflushed_frees 4096, freed 0, defer 0 + 4096, unloaded time 19308 ms, loading_time 0 ms, ms_max_size 132784128, max size
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 178, spa TEST_POOL, vdev_id 0, ms_id 8, smp_length 1304, unflushed_allocs 86016, unflushed_frees 143360, freed 0, defer 0 + 16384, unloaded time 19308 ms, loading_time 0 ms, ms_max_size 132550656, ma
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 178, spa TEST_POOL, vdev_id 0, ms_id 9, smp_length 344, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19309 ms, loading_time 0 ms, ms_max_size 133435392, max size error 1
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 9, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size err
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 10, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 11, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 12, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 13, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 14, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 15, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19885 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 16, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19886 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 17, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19886 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 18, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 19, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 20, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 21, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 22, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 23, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 24, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 25, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
Mar 28 13:31:24 truenas metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 9, spa ARCHIVE_POOL_VM, vdev_id 0, ms_id 26, smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 19982 ms, loading_time 0 ms, ms_max_size 17179869184, max size er
seldo
I did the same in FreeNAS 11.3 U5, and I don't have any error when using the VM and rebooting.
Mar 28 07:46:22 freenas Beginning pools import
Mar 28 07:46:22 freenas Importing ARCHIVE_POOL_VM
Mar 28 07:46:22 freenas Importing TEST_POOL
Mar 28 07:46:22 freenas Pools import completed
I will try on the server now. I hope it is the same.
I will then open a ticket against 12.0 U2.1 for these message.
Could it be that something has changed on how the server shuts down?
seldo
On FreeNAS 11.3 U5, I still have it.
It looks like the issue arrises when I have the SSD connected to the ODD SATA port of the motherboard (in my case, I have 4xSATA connected in a signal proprietary cable + 1xSATA with a standard SATA connector that is normally used for the ODD.
Since I also saw some issues on the VM, I am wondering if that's the SSD causing the issue or the 2x 8TB...
Mar 28 18:45:16 bob Beginning pools import
Mar 28 18:45:16 bob Importing ARCHIVE_POOL
Mar 28 18:45:16 bob disk vdev '/dev/gptid/60fda34c-8fcb-11eb-895c-00fd45fc0de0': best uberblock found for spa ARCHIVE_POOL. txg 38
Mar 28 18:45:16 bob spa_load(ARCHIVE_POOL, config untrusted): using uberblock with txg=38
Mar 28 18:45:16 bob spa=ARCHIVE_POOL async request task=1
Mar 28 18:45:16 bob spa_load(ARCHIVE_POOL, config trusted): LOADED
Mar 28 18:45:16 bob txg 40 open pool version 5000; software version 5000/5; uts  11.3-RELEASE-p14 1103000 amd64
Mar 28 18:45:16 bob spa=ARCHIVE_POOL async request task=32
Mar 28 18:45:16 bob txg 42 import pool version 5000; software version 5000/5; uts  11.3-RELEASE-p14 1103000 amd64
Mar 28 18:45:16 bob Importing SSD_POOL_TEST
Mar 28 18:45:16 bob Pools import completed
seldo
I've added my two drives from Nas4Free/Ximanas and imported them (but they didn't get an upgrade).
I now get:
Mar 28 19:18:43 bob Beginning pools import
Mar 28 19:18:43 bob Importing ARCHIVE_POOL
Mar 28 19:18:43 bob spa_load($import, config trusted): LOADED
Mar 28 19:18:43 bob spa_load($import, config trusted): UNLOADING
Mar 28 19:18:43 bob spa_import: importing ARCHIVE_POOL
Mar 28 19:18:43 bob spa_load(ARCHIVE_POOL, config trusted): LOADING
Mar 28 19:18:43 bob disk vdev '/dev/gptid/4a941c7d-8fe8-11eb-999f-00fd45fc0de0': best uberblock found for spa ARCHIVE_POOL. txg 14
Mar 28 19:18:43 bob spa_load(ARCHIVE_POOL, config untrusted): using uberblock with txg=14
Mar 28 19:18:43 bob spa=ARCHIVE_POOL async request task=1
Mar 28 19:18:43 bob spa_load(ARCHIVE_POOL, config trusted): LOADED
Mar 28 19:18:43 bob txg 16 open pool version 5000; software version 5000/5; uts  11.3-RELEASE-p14 1103000 amd64
Mar 28 19:18:43 bob spa=ARCHIVE_POOL async request task=32
Mar 28 19:18:43 bob txg 18 import pool version 5000; software version 5000/5; uts  11.3-RELEASE-p14 1103000 amd64
Mar 28 19:18:43 bob Importing MAIN_POOL
Mar 28 19:18:43 bob spa_tryimport: importing MAIN_POOL
Mar 28 19:18:43 bob spa_tryimport: using cachefile '/data/zfs/zpool.cache.saved'
Mar 28 19:18:43 bob spa_load($import, config trusted): LOADING
Mar 28 19:18:43 bob disk vdev '/dev/ada1': best uberblock found for spa $import. txg 2575211
Mar 28 19:18:43 bob spa_load($import, config untrusted): using uberblock with txg=2575211
Mar 28 19:18:43 bob spa_import: importing MAIN_POOL
Mar 28 19:18:43 bob spa_load(MAIN_POOL, config trusted): LOADING
Mar 28 19:18:43 bob disk vdev '/dev/ada1': best uberblock found for spa MAIN_POOL. txg 2575211
Mar 28 19:18:43 bob spa_load(MAIN_POOL, config untrusted): using uberblock with txg=2575211
Mar 28 19:18:43 bob spa=MAIN_POOL async request task=1
Mar 28 19:18:43 bob spa_load(MAIN_POOL, config trusted): LOADED
Mar 28 19:18:43 bob txg 2575213 open pool version 5000; software version 5000/5; uts  11.3-RELEASE-p14 1103000 amd64
Mar 28 19:18:43 bob spa=MAIN_POOL async request task=32
Mar 28 19:18:43 bob txg 2575215 import pool version 5000; software version 5000/5; uts  11.3-RELEASE-p14 1103000 amd64
Mar 28 19:18:43 bob Pools import completed
root@bob[~]# zpool status
  pool: ARCHIVE_POOL
state: ONLINE
  scan: none requested
    ARCHIVE_POOL                                    ONLINE       0     0     0
        gptid/4a913f78-8fe8-11eb-999f-00fd45fc0de0  ONLINE       0     0     0
        gptid/4a941c7d-8fe8-11eb-999f-00fd45fc0de0  ONLINE       0     0     0
  pool: MAIN_POOL
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
    still be used, but some features are unavailable.
  scan: scrub repaired 0 in 0 days 04:34:59 with 0 errors on Mon Jan  4 05:53:08 2021
    MAIN_POOL   ONLINE       0     0     0
        ada2    ONLINE       0     0     0
        ada1    ONLINE       0     0     0
  pool: freenas-boot
state: ONLINE
    freenas-boot  ONLINE       0     0     0
      da0p2     ONLINE       0     0     0
I have to say, I don't know what's happening, and it's worrying me.
seldo
Just for completion on this thread, if anyone looks for the same thing in the future:
I opened a Jira issue and got a well commented feedback.
In short: if the pools import properly and the log don't show errors, you are fine.
For more details, check the Jira issue.
