Ed Blackmond
- Nov 17, 2014
I am using FreeNAS and iSCSI to aggregate storage from different systems creating a hyper-converged storage/compute environment. Each system with storage runs an iSCSI target server and exports each of its drives as a different LUN. The FreeNAS server runs the iSCSI initiator to load all the LUNs. This works just fine when I issue:
iscsictl -Aa
manually after boot, then import all the volumes. I would like to set this up to load automatically when the system boots. If I place:
iscsictl_enable=“YES”
iscsictl_flags=“-Aa”
into
/conf/base/etc/rc.conf
all the drives get loaded, but the system hangs in a loop with the iSCSI initiator attempting to “login” to the target servers. It does not get past this point, so the ssh daemon doesn’t get started and there is no way into the machine.
However, if I rename:
/conf/base/etc/rc.d/iscsictl
to
/conf/base/etc/rc.d/yyiscsictl
the iSCSI LUNs get loaded about 25 seconds after the FreeNAS menu gets displayed on the console. The ZFS volumes still must be imported manually. If I delete
rather than rename it, no iSCSI LUNs get loaded.
Question:
What is the best way to get the iSCSI LUNs loaded on boot so that they will be seen when FreeNAS looks at the drives and imports all the pools?
Configuration
In the interest of full disclosure, FreeNAS is running on a virtual machine using linux KVM as a hypervisor. I have read the posts on not doing this and don’t believe they apply here. The FreeNAS VM is assigned multiple cores and gets at least 1GB of RAM for each TB of storage.
I am running:
FreeNAS-9.3-STABLE-201501162230
The hardware running the FreeNAS VM is a SuperMicro X9DRT-IBFF motherboard with 256GB ECC-DRAM, two Intel E5-2658v2 (10 cores each), two on-board 1Ge ports, one on-board Mellanox Connect-X3 port configured as 40Ge and a two port Mellanox Connect-X3 card configured as 40Ge ports. The network interfaces are passed through to the FreeNAS VM using virtio. Two 25GB drive partitions (from different systems) are passed through to the FreeNAS VM using virtio for use as the mirrored ZFS root partition. The iSCSI traffic is on a dedicated 40be network interface. The other 40Ge interfaces are for accessing FreeNAS from other VMs and passing data between VMs.
The
/base/conf/etc/iscsi.conf
file contains:
hds8right {
InitiatorName = iqn.1992-05.com.themis.freenas
TargetAddress = 192.168.15.160
TargetName = iqn.1992-05.com.themis.iscsi.hds8right
hds8left {
TargetAddress = 192.168.15.161
TargetName = iqn.1992-05.com.themis.iscsi.hds8left
iscsictl -Aa
into
to
Question:
Configuration
I am running:
The
file contains:
hds8right {
hds8left {
