I have a ST3000DM001 1CH166 CC29 drive and sometime ago, i updated the firmware from freenas command line i think.
The drive correctly shows the model / vendor and version but the serial number appears as {'s
The drive info from seachest on linux shows the below and I note it shows 2.2TB and gparted shows 2.7TB
seachest firmware update won't run against it, because it is not recognized as a seagate drive.
seatools also doesn't on it, presumably because of the bad SN
is there any tool that can be used to repair the s/n?
is 2.2TB correct? I tried to clone a drive to this drive, and from this drive I have a hudge number of bad clusters.
Vendor ID: ST3000DM Model Number: 001-1CH166 Serial Number: {'s Firmware Revision: CC29 World Wide Name: Not Supported Drive Capacity (TB/TiB): 2.20/2.00 Temperature Data: Current Temperature (C): Not Reported Highest Temperature (C): Not Reported Lowest Temperature (C): Not Reported Power On Time: Not Reported Power On Hours: Not Reported MaxLBA: 4294967295 Native MaxLBA: Not Reported Logical Sector Size (B): 512 Physical Sector Size (B): 512 Sector Alignment: 0 Rotation Rate (RPM): Not Reported Form Factor (inch): Not Reported Last DST information: Not supported Long Drive Self Test Time: Not Supported Interface speed: Max Speed (MB/s): 5.00 (FAST-5) Negotiated Speed (MB/s): Not Reported Annualized Workload Rate (TB/yr): Not Reported Total Bytes Read (B): Not Reported Total Bytes Written (B): Not Reported Encryption Support: Not Supported Cache Size (MiB): Not Reported Read Look-Ahead: Not Supported Write Cache: Not Supported SMART Status: Unknown or Not Supported ATA Security Information: Not Supported Firmware Download Support: Not Supported Specifications Supported: SCSI Features Supported: None reported or an error occurred while trying to determine the features.
