sparse VM sizing
hescominsoon
I have scale up on my testing server(see signature) and i setup a 150 gig zvol as the disk per the wizard. According to storage it is using 150 gigs of disk space which leads me to believe this was not a thin provisioned VM. Can kvm not work with thin provisioned drives or is this an artifact of the webui not being quite finished in this regard?
ornias
I think spares is an additional setting you need to check the checkbox for on the zvol....
Patrick M. Hausen
zfs inherit -S refreservation mypool/my/zvol ...
Might have slightly different syntax on SCALE than on CORE, but clearing the refreservation attribute turns your volume into a sparse one.
hescominsoon
in scale that sparse option is not in the web ui...heance the question....:) If it's supposed tob e there then i'll fle a bug report..:)
craigywsm
I have tried to get Sparse storage working in SCALE and it look like it is not working, Please can this be added as a feature request?
Patrick M. Hausen
What's the result of zfs get refreservation yourpool/path/to/volume?
Patrick M. Hausen
Yes, this looks like a sparse volume. :wink:
