HitmanThe47
- May 7, 2021
Hello guys,
Well search for this problem and find no solution...
error: ld-elf.so.1: /usr/local/lib/libmediainfo.so.0: Undefined symbol "tfsxml_init"
To replicate:
Start sonarr like usualy:
[Info] Bootstrap: Starting Sonarr - /usr/local/share/sonarr/Sonarr.exe - Version 3.0.6.1342
[Info] AppFolderInfo: Data directory is being overridden to [/usr/local/sonarr]
[Info] Router: Application mode: Interactive
[Info] MigrationLogger: *** Checking database for required migrations data source=/usr/local/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] MigrationLogger: *** Checking database for required migrations data source=/usr/local/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] OwinHostController: Listening on the following URLs:
[Info] OwinHostController: http://*:8988/sonarr/
[Info] SonarrBootstrapper: Starting Web Server
[Info] RecycleBinProvider: Recycle Bin has not been configured, cannot cleanup.
[Info] ImportListSyncService: Starting Import List Sync
[Info] ImportListSyncService: Processing 0 list items
[Info] RefreshSeriesService: Skipping refresh of series: The 100
[Info] RssSyncService: Starting RSS Sync
[Info] DiskScanService: Scanning The 100
[Info] DiskScanService: Completed scanning disk for The 100
[Info] DiskScanService: Scanning The Book of Boba Fett
[Info] DiskScanService: Completed scanning disk for The Book of Boba Fett
[Info] MetadataService: Series folder does not exist, skipping metadata creation
[Info] RefreshSeriesService: Updating The Boys
And the it dies...
Made a frsh install of sonarr and it starts fine.
Import from backup and this happens again.
Can you guys help!!
To replicate:
And the it dies...
Can you guys help!!
