IceBoosteR
- Sep 27, 2016
Hi folks,
I don't know why I am writing this short thread, but sometimes FreeNAS is jumping me again and again in my face. By this I mean things are too complicated. Normally it is not, but here is my story.
I have installed FreeNAS on bare-metal to avoid problems with the hypervisor. I have plenty CPU cycles/resources left and want to do more on my server.
First problem, want to go with latest emby, as the plugin is often not up-to date. Easy I thought, created a new jail updated ports and dang. I am on 11.0-U4 so the jail template is on 11 and has no support from FreeBSD anymore, so the port upgrade fails. Even with plenty of workaround, MAKE fails because of inconsistency...
I could also not update the jail to 11.1...
Next problem with 11.1 on my test machine -> Jails are still on 11.0? Yes WTF!
Bug ticket opened and the kind answer was: Use IOCAGE. Yeah I could but I want the simplicity of the jails I have now, adding storage and so on. No way.
Next try, use bhyve. Some problems with the keyboard, problems at boot and no chance to add local filesystem from GUI. I have no problem with doing things from CLI, as I do this every day at work, but with FreeNAS I should use the GUI and I don't want to break things apart. Ok yeah got it....
Sometimes I wished I installed it in ESXi and use FreeNAS only for serving storage. OR I need to buy more servers. Meeeh.
Sorry but this has to get out of mind and writing down helps -__-
