alieg
- Jul 12, 2013
I have finally found an opportunity to spend some time updating my home server with another attempt at upgrading to Scale but I'm running into this error:
("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer'))
The More Info:
My System:
Version: TrueNAS-13.0-U4
CPU: Intel(R) Core(TM) i5-3470T CPU @ 2.90GHz
RAM: 12GB
Disk: 1TB
Available Space: 871.76GiB
I know it's a low powered system but it does what I need it to. I run HomeAssistant on it and store some files. I'd like to upgrade to Scale to be able to update HomeAssistant beyond the last version for Core.
The More Info:
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 438, in _error_catcher yield File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 519, in read data = self._fp.read(amt) if not fp_closed else b"" File "/usr/local/lib/python3.9/http/client.py", line 463, in read n = self.readinto(b) File "/usr/local/lib/python3.9/http/client.py", line 507, in readinto n = self.fp.readinto(b) File "/usr/local/lib/python3.9/socket.py", line 704, in readinto return self._sock.recv_into(b) File "/usr/local/lib/python3.9/ssl.py", line 1242, in recv_into return self.read(nbytes, buffer) File "/usr/local/lib/python3.9/ssl.py", line 1100, in read return self._sslobj.read(len, buffer) ConnectionResetError: [Errno 54] Connection reset by peer During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 753, in generate for chunk in self.raw.stream(chunk_size, decode_content=True): File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 576, in stream data = self.read(amt=amt, decode_content=decode_content) File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 541, in read raise IncompleteRead(self._fp_bytes_read, self.length_remaining) File "/usr/local/lib/python3.9/contextlib.py", line 137, in __exit__ self.gen.throw(typ, value, traceback) File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 455, in _error_catcher raise ProtocolError("Connection broken: %r" % e, e) urllib3.exceptions.ProtocolError: ("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 393, in __run_body rv = await self.middleware.run_in_thread(self.method, *([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1155, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update.py", line 320, in download return self.middleware.call_sync('update.download_update', job, train, location, 100) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1295, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1335, in run_coroutine return fut.result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 439, in result return self.__get_result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 391, in __get_result raise self._exception File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update.py", line 324, in download_update success = await self.middleware.call('update.download_impl', *args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1279, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1247, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update_/download_freebsd.py", line 20, in download_impl result = self.middleware.call_sync('update.download_impl_scale', job, train, location, progress_proportion) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1306, in call_sync return methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update_/download.py", line 48, in download_impl_scale for i in r.iter_content(chunk_size=8 * 1024 * 1024): File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 756, in generate raise ChunkedEncodingError(e) requests.exceptions.ChunkedEncodingError: ("Connection broken: ConnectionResetError(54, 'Connection reset by peer')", ConnectionResetError(54, 'Connection reset by peer'))
My System:
RAM: 12GB
Disk: 1TB
