alberthartland
- Sep 2, 2018
Hi all,
I've been struggling to get linux VM's to boot under TrueNAS 12 and tried all manner of different options including different distros (debian net installer, rancheros 1.5.x iso)
The symptoms are the serial connection reporting 'connected' and there would be no other output. VNC would work, and report EFI boot failures. The VMs that I created would not boot and would throw errors under 12.0 if I tried to stop them (apparently fixed under 12.1)
The solution:
* bhyve can only boot 64bit VMs -
The documentation doesn't note this and although I would expect most ppl to be trying with 64bit iso's, the ones I tried with to get a minimal install may not have been.
Other references that may help anyone finding this post:
- https://www.jongibbins.com/solving-uefi-boot-problems-on-bhyve-freenas-vm/
This config worked for me:
Virtual CPUs: 2
Cores: 1
Threads: 1
Memory Size: 2.00 GiB
Boot Loader Type: UEFI
System Clock: LOCAL
UBUNTU ISO: ubuntu-20.04.1-live-server-amd64.iso
NIC type: E1000
VNC: enabled
The solution:
Virtual CPUs: 2
Cores: 1
Threads: 1
System Clock: LOCAL
NIC type: E1000
VNC: enabled
