I updated FreeNAS 9.10-U5 to FreeNAS 11-RC a few days ago. Everything is working great, including all my jails!
I was trying to setup an Ubuntu Mate 16 VM, and followed the Guide.
These are the settings:
CPU: 1
Memory 1024
UEFI
Autostart Y
Devices are
NIC (default intel)
VNC (port 5904, Wait to boot Y)
Disk (6GiB zvol, AHCI)
CD-ROM (ubuntu mate iso)
When I start the VM, the State is "Running". And it will stay running and will not change.
However, when I connect with VNC Viewer on port 5904 (tried real vnc and tight vnc, same results on both), I get a "Connection closed expectantly" and the VM State changes to STOPPED immediately. I do not even get the EFI screen, no boot screen, nothing.
I tried other iso's, same result. Restart FreeNAS, still the same. VMs just dont start. I also changed the Picture Quality to everything (but Auto as its not recommended).
When I check /var/log/message, i have only these entries:
I tried to find some logs that may show the actual problem, but I cant find anything.
Any advise why this is happening? What can I do or try.
Cheers,
Eddi
Edit: For completeness sake, these are the hardware specs:
Supermicro X8 MB
Intel X3460 CPU
32GB ECC RAM
LSI HBA in IT mode
6x 4TB HGST Enterprise HDD's
CPU: 1
Memory 1024
UEFI
Autostart Y
Devices are
NIC (default intel)
Jun 29 13:51:21 freenas tap0: Ethernet address: 00:bd:12:87:8f:00 Jun 29 13:51:21 freenas kernel: tap0: promiscuous mode enabled Jun 29 13:51:21 freenas kernel: tap0: link state changed to UP Jun 29 13:51:21 freenas kernel: tap0: link state changed to UP Jun 29 13:51:36 freenas kernel: tap0: link state changed to DOWN Jun 29 13:51:36 freenas kernel: tap0: link state changed to DOWN
Cheers,
Eddi
Supermicro X8 MB
Intel X3460 CPU
32GB ECC RAM
LSI HBA in IT mode
