melloa
- May 22, 2016
Guys,
Convinced a friend to migrate from QNAP and Sinology to FreeNAS. He is running FreeNAS-11.1-U5 on an ESXi 6.5 VM with this configuration: X9DRi-LN4F+ on a Supermicro 2U 12 bay 2x Xeon E5-2630 6 Core 6Gbps Raid Server 64GB SATADOM Boot.
He needs couple jails to run some external rsyncs, but we can't get the interface to obtain an IP from the DHCP or assign a fix IP to it.
Reading posts here, I have seen some tunables been used (ifconfig bridge0 addm em0), but that has not solved the issue, but again that post was related to 11.1-U1, so that should be fixed by now.
When I look at the host network, I see:
And the jail network has:
Any ideas?
Thanks!
ifconfig em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:0c:29:5d:ad:fe hwaddr 00:0c:29:5d:ad:fe inet 10.10.10.200 netmask 0xffffff00 broadcast 10.10.10.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:14:f2:8f:89:00 nd6 options=9<PERFORMNUD,IFDISABLED> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 2000 member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ac:50:00:04:0a hwaddr 02:ac:50:00:04:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
root@jail1:/ # ifconfig lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether ba:d0:aa:a3:28:0d inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
Any ideas?
Thanks!
