Narann
Neophyte
- Jun 3, 2012
Hi all!
== First step: Install FreeNAS 8 using a USB key ==
This is just a "bonus" as this is something which is very simple to do but I spend some time to try how to.
To install FreeNAS 8 using a USB key, open "FreeNAS-8.0.4-RELEASE-p2-x64.iso" using any extractor.
In this file, extract "FreeNAS-x64.img.xz".
Then open this file using any extractor then extract "FreeNAS-x64.img".
Once this is done, get your usb key drive name (using "sudo fdisk -l". Mine was "/dev/sde") and do:
This take longtime.
Once your nice USB key in you hand plug it, set your BIOS to ensure the computer will boot on the USB key.
== run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config ==
I've got this error and try to find the solution searching on internet.
Their is many post about this but the solution is never clearly writted (https://fccomputing.wordpress.com/2010/04/21/run_interrupt_driven_hooks-still-waiting-error-fix/)
So, if you have this message during FreeNAS 8 boot:
Just go on your BIOS (me it's an ASUS one) and set:
This has resolve the problem for me.
This post was just my intention to share the solution has was hard for me to find. :)
Good luck all!
sudo dd if="FreeNAS-x64.img" of=/dev/sde
This take longtime.
(prob7::umass-sim0:0:0:0): SCSI sens: UNIT ATTENTION asc:28,0 (Not ready to ready change, medium may have changed) run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config run_interrupt_driven_hooks: still waiting after 120 seconds for xpt_config ...
Bios/Advanced/Onboard Devices Configuration/1394 Controller -> [Disabled]
Good luck all!
