Software recommendation
DD4711
this is my first post here and my first steps with FreeNAS. Hello :)
I'm currently checking, if FreeNAS can replace my Synology NAS. Therefore I am searching for software for FreeNAS to satisfy my needs. I would appreciate your help with finding the right software and right installation type. The needs aren't very special but I am little overlaoded because of the diverse installation methods of software and confused about selecting the right software. My Hardware is a HPE Microserver Gen10.
Requirements about the choice:
  • easy to administer
  • easy to backup and restore
  • stable
  • not internet connection required, only in house sync etc.
  • should work "out of the box" without lots of configuration outside FreeNAS GUI - so plugins are best choice?!
OK, here are my current needs regarding services with my choice for specific software. Could you please recommend me some software?
  • Photo Gallery for clients: Plex
  • Video streaming for clients: streaming of my home made videos
  • Music Server / DLNA: PLex
  • Calendar, Contacts Sync with clients: Owncloud or even Baikal?
  • Cloud / File Sync option for files with clients: Owncloud
  • Wiki Software: ?
  • Encrypted Backup of FreeNAS with Data on USB HDD
Thanks a lot!
Chris Moore
You should not decide what hardware you are using before you determine the software.
The hardware is determined by the software.
Have you already purchased the microserver?
DD4711
Yes I did. I think this hardware should be fine for my requirements. As told I am currently testing, maybe after the test it will look different and yes maybe also with other hardware
